Bongi66 Posted December 26, 2020 Share Posted December 26, 2020 HiMy son has a number of DCC ready 00gauge models, and is keen to put decoders in them to run with his e-link. is there somewhere where we can match model numbers to the required decoder or can they be universally applied? Many thanks in advance Confused Mum. Link to comment Share on other sites More sharing options...
Chrissaf Posted December 26, 2020 Share Posted December 26, 2020 In principle, decoders are universal, but with these caveats. Decoders come in different physical formats. This list is not exhaustive and covers the more common ones. NEM652 8 PinMTC21 21 Pin4 Pin6 Pin Below are the three DCC Ready socket /decoder types more commonly found in Hornby locomotives. The 8 Pin version on the right being the most prominent type. The 4 pin type in the middle is more commonly found in small Hornby Tank type locomotives with 4 or 6 wheels. The 6 Pin type on the left is very much more specialised and only found in a very small number of Hornby models./media/tinymce_upload/d2a91e6eb59097aefe09bbb38d5aa992.jpg So the first task is to identify which DCC Ready socket / decoder type the model requires. This is usually stated on the box the model comes in or on any included data-sheet documentation in the box. Once you know the socket / decoder type, then the decoder manufacturer and exact decoder part can be selected. For Hornby The NEM652 8 Pin decoders are the R8249 for basic motor / lighting control OR a TTS variant for a decoder with sound. Different TTS [Twin Track Sound] decoders are made for different types and Class of locomotives as the sounds are matched to the loco type. Not all TTS decoder installations are 'plug n play' and usually need some soldering and modelling skills.The 4 Pin Hornby decoder [basic motor control only] is the R7274 [or X9659].The 6 Pin Hornby decoder [basic motor control plus directional lights option] is the R7150 Hornby decoders are very basic and do not have a lot of adjustable features. There are many decoder brands that are totally compatible with Hornby DCC Ready locomotives. Note that inside the loco. The DCC socket connector will have a small connector plugged into it. The function of this connector is to 'pass through' the DC Analogue power from the track to the motor when being used on a DC Analogue controlled layout. This plugged in connector is removed and replaced with the appropriate DCC decoder to convert the locomotive to DCC control. The removed connector should be kept and stored in a safe place as it is useful to help diagnose any future faults. All decoders are shipped from the factory with a default DCC Address set as 003 ... this address should be used first to test the loco and decoder are functioning correctly. Once happy with the outcome of that test, the DCC Controller should be used to change the default 003 address to some uniquely different address. I would suggest for a newbie starting out, that the address used should be restricted to a DCC Address in the DCC Short Address range 001 to 127. Avoiding, of course, the 003 DCC Address. The Hornby eLink does not support the operation of a DC Analogue loco placed on a DCC powered track. Even if it did support DC Analogue operation, it is strongly advised that such an option should not be used, as it risks burning out the motor. Your Son's 'DCC Ready' locomotives should not be placed on the eLink powered track without first being fitted with a decoder. THIS IS A VERY LONG REPLY WITH IMAGES. PLEASE DO NOT CLICK THE BLUE BUTTON TO REPLY. Please read the TIP below with regard 'How To' reply. TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button. Particularly as my reply includes an image, using the 'Blue Button' may result in your reply being held back for image approval, even though it is an existing image. See also – further TIPs on how to get the best user experience from this forum. TIPs include 'How to post images' and 'How to make links clickable'.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/ Link to comment Share on other sites More sharing options...
