Chrissaf Posted January 11, 2021 Share Posted January 11, 2021 I bet you haven't got a Multimeter. If you had one you could measure the voltage output of the Select power supply which should read 15 volts DC with centre pin positive. In the absence of a Multimeter then a car 12 volt side light bulb connected across the power pack output connector would show if the power pack is working. If the power pack is working, then the Select is likely faulty and either needs replacement if still under Warranty or repair if outside Warranty. If repair / replacement is needed, contact Hornby Customer Services [number at bottom of page under 'Contact us'] to discuss. In my view a Multimeter is an essential tool to have in the toolbox for any hobby involving electricity. Multimeters can be purchased cheaply on ebay for less than £8 delivered. I take it that you have checked the fuse in the 3 Pin Mains Plug (assuming UK). TIP: As a newbie poster on the forum, just be aware that the 'Blue Button with the White Arrow' is not a 'Reply to this post' button. If you want to reply to any of the posts, scroll down and write your reply in the reply text box at the bottom of the page and click the Green 'Reply' button. See also – further TIPs on how to get the best user experience from this forum. TIPs include 'How to post images' and 'How to make links clickable'.https://www.hornby.com/uk-en/forum/tips-on-using-the-forum/ Link to comment Share on other sites More sharing options...
Chrissaf Posted January 11, 2021 Share Posted January 11, 2021 Please help , my hornby select has died , no power no response . i was altering a loco acceleration but when finished select was dead Link to comment Share on other sites More sharing options...
