bocaj Posted July 1, 2011 Posted July 1, 2011 Hi everyone,I am getting to that stage where I am ready to wire up my layout. I am planning to make all of my points moterised to avoid damaging scenery. Now, I know that you can put point moters underneath the board but can you have point decoders underneath the layout? Also, will I still beable to operate my layout by hand just for the few DC trains I will have?Please Help,Jacob
FinnerZ Posted July 1, 2011 Posted July 1, 2011 The dedcoder can be fixed under the layout, but be warned that sometimes the screws poke out through the top of the baseboard so best to mount it under a buildinig or future building (or just put a tree or car over them). The points can also be switched by hand, but unless you're planning to use computer controll for your points, you can do what some people do and controll your points using a separate analogue power supply not connected to the layout. Good luck.
Brightstar Posted July 1, 2011 Posted July 1, 2011 Hi FinnerZ,I would alway recommend filing the ends of the screws protruding through the boards so they are flush with the top of the boards. Leaving them sticking out of the boards surface is never a good idea. If you cannot gain access to the screws from the top of the baseboards remove them and rub the ends on a file to reduce their length. The other alternative is to use shorter screws, if you have them.Word of advice, never, ever leave screws or nails protruding from the surface or the underrneath of a baseboard especislly the underneath of the board as you could injure your scalp when you crswl under the boards. The same applies to cables, secure then without any loops dangling down, otherwise you could pull them out of connections to the rsils, points etc.
Rog RJ Posted July 1, 2011 Posted July 1, 2011 Or screw them to the baseboard legs, or fit spacer washers
walkingthedog Posted July 1, 2011 Posted July 1, 2011 Quite right Rog. You'd think screws only came in one length!
poliss Posted July 1, 2011 Posted July 1, 2011 Screws don't poke through my 12mm thick baseboard. :-) Do poke through the lid though. :-( I wish I'd used 12mm for that too, as not only do the screws poke through, it's also bendy. :-(Yes, shorter screws would be good, but try finding shorter screws for MDF. There's none here.
bocaj Posted July 1, 2011 Author Posted July 1, 2011 Hi everyone,If the case is that screws will stick out of the base board I'll just put them all in the of-scene area of the board, along with my controllers, turntable and a few locomotives.I'll proboly do some more reserch into it.Thanks for the help,Jacob
FinnerZ Posted July 1, 2011 Posted July 1, 2011 The reason I haven't done any of the things recommended is that I hadn't noticed that they protruded untill I had done all the wiring (and now one of them has come loose). Luckily they protrude very near the track and as I'll probably have to redo some of the wiring I will try shorter screws. While using my grandfather's garage is a problem in that I have very little time with my layout (only about 10-15 days a year!) it does mean I have access to a wide range of tools, screws and other useful items (like mains wire and bauden cables). I'll try and sort this out next time. Thank's for the advise. And to Jacob, all you have to do is to put a thin bit of wood between the decoder and the baseboard - one of the main attractions of DCC points is being able to put the unit as near to the points as posssible without miles of wires. Good luck.
bocaj Posted July 2, 2011 Author Posted July 2, 2011 Thanks FinnerZ,So aslong as you out some wood underneath the point decoder it should be fine,Do you recomend any thickness or type of wood?
FinnerZ Posted July 4, 2011 Posted July 4, 2011 Something cheap (you won't see it), and it has to be thick enough so that the decoder screws don't come through the baseboard, i.e. if the screws are 5 cm long (which they probably aren't), and your baseboard was 2.5 cm thick, you would need wood at least 2.5 cm thick. Hardboard is quite thin but very cheap.
bocaj Posted July 4, 2011 Author Posted July 4, 2011 Hi FinnerZ,Thanks for telling me how to do it, i'll take your advice into acount.Thanks for the help,Jacob
