Maltese Mike Posted July 5, 2021 Share Posted July 5, 2021 Hi, I have a R292 Class 5 which I believe is fitted with a Type 6 Ringfield motor. I would like to fit a Hornby Sound Decoder to it. The motor is tender driven with the black wire pickup attached to the loco via the loco to tender connector. As I can't see a Red wire in the tender I am guessing that the chassis is live.My question is, do I have to insulate the brush securing plate with a nylon screw or am I missing something? Should I try another form of fitting?Thanks Link to comment Share on other sites More sharing options...
Chrissaf Posted July 5, 2021 Share Posted July 5, 2021 Check out Brian Lambert's Ringfield motor DCC fitting guideBrian Lambert's Decoder Install Page [scroll down for Ringfield]Also, his 'Stall Test' instructions [needed to check the decoder spec is suitable for your motor]Brian Lambert's 'Stall Test' guide Link to comment Share on other sites More sharing options...
Maltese Mike Posted July 5, 2021 Author Share Posted July 5, 2021 Thanks for the link to Brian Lamberts guide. Really useful information, answers my current question and think it may answer other future ones if they arrive. Once again, thank you very much 😊 Link to comment Share on other sites More sharing options...
