Maltese Mike Posted August 19, 2021 Share Posted August 19, 2021 I've just bought a R3740 Class 92 loco. It has come DCC ready. I tested it on an Anologue track and it's performed well and the directional lights worked as they should. I've now fitted a R8249 hornby decoder, the loco runs ok but the lights no longer work. Any ideas please? Link to comment Share on other sites More sharing options...
Rog RJ Posted August 19, 2021 Share Posted August 19, 2021 Have you switched the lights on? They don't come on automatically with DCC. Apologies if you already know this. Link to comment Share on other sites More sharing options...
Smudge617 Posted August 19, 2021 Share Posted August 19, 2021 Depending on your controller 0 or 1 will be the On/Off switch for the lights. If they still don't work check the installation of the decoder, if you've installed it the wrong way round the lights won't work. Link to comment Share on other sites More sharing options...
Chrissaf Posted August 19, 2021 Share Posted August 19, 2021 The Decoder CV29 typically also has to be 128 Speed Step enabled for directional lights to work. CV29 with a value of 6 will be a compatible 128 speed step value OR 2 if you want 128 speed steps with DC Operation disabled.Some R8249's have been reported to have CV29 with a zero value. Zero in CV29 will typically prevent directional lights working. Link to comment Share on other sites More sharing options...
Maltese Mike Posted August 21, 2021 Author Share Posted August 21, 2021 Thanks everybody for your advise. As the lights were working automatically on DC I made the schoolboy error of assuming that they would work automatically on DCC. Rog, no need to apologise, I didn't know I had to switch them on 🤔. Thanks again, you've all given me tips which may help with future projects 👍👍 Link to comment Share on other sites More sharing options...
