Bicester Derry Posted January 13, 2022 Share Posted January 13, 2022 Can anyone help? I've just taken delivery of the new APT (looks fab), but I am a tad confused; do I need 2 x 8 pin decoders? One for the drivers car and one for the motor car or just 1 for the motor car?The instructions seem to be somewhat lacking on the subject apart from showing where to fit them, and once fitted, how do I programme the second one in the drivers car? Link to comment Share on other sites More sharing options...
Going Spare Posted January 13, 2022 Share Posted January 13, 2022 This subject has been aired in a previous post and it was generally accepted that, as per the instructions with the pack, one decoder would be needed in each driving car and one in each non-driving motor (NDM) - i.e. 3 decoders for your 5-car set.Others will advise on programing. Link to comment Share on other sites More sharing options...
Bicester Derry Posted January 13, 2022 Author Share Posted January 13, 2022 I am much obliged. Link to comment Share on other sites More sharing options...
Jupiter 1707822591 Posted January 13, 2022 Share Posted January 13, 2022 Place all three on the track (only these ) and programme together .the days of the decoder not seeing a motor should hopefully be long gone .Let us know which DCC controller you are using . Link to comment Share on other sites More sharing options...
Bicester Derry Posted January 13, 2022 Author Share Posted January 13, 2022 Thank you John, I will be using Hornby R8249 8 pin decoders and I use Railmaster on my PC to control/programme the layout. Link to comment Share on other sites More sharing options...
Chrissaf Posted January 13, 2022 Share Posted January 13, 2022 Just note that the R8249 is an older design decoder and does normally need to see a motor load when installed in non motorised stock for programming.If you experience issues programming the non motor car decoders, then temporarily relocate them to the motor car for programming, then put them back into the non motorised cars after they have been programmed.Can I also take the opportunity to advise that there is no need to requote the whole previous post [now removed] when your reply is directly after it. The "blue button with white arrow" is not a "Reply to this post" button. It is preferred if you would scroll to the bottom of the page and write any reply you want to make in the "Reply Text Box" and click the green "Post Reply" button. Thank you in advance for your cooperation. Link to comment Share on other sites More sharing options...
Bicester Derry Posted January 13, 2022 Author Share Posted January 13, 2022 Thanks Chris, much obliged (and note I pressed the correct button)! Link to comment Share on other sites More sharing options...
Chrissaf Posted January 13, 2022 Share Posted January 13, 2022 Thank you, and I hope the APT gets DCC'd without further issue. Link to comment Share on other sites More sharing options...
