bob 340 Posted January 31, 2022 Share Posted January 31, 2022 Hi can anyone help me to DCC my 0 6 0 Pannier tank loco fitted with later type motor there is one wire connected the top of it with a noise suppresser which connected to it and then this is fitted to a screw to the motor holding it down any help and tips will be most welcome thanks bob. Link to comment Share on other sites More sharing options...
Jupiter 1707822591 Posted January 31, 2022 Share Posted January 31, 2022 The motor makes a connection onto the chassis. This connection must be isolated from the chassis and the grey wire connected, the orange goes where the red is.Then connect the Reds together, snip of the suppressor and connect the black onto the wire going to the chassis. Insulate the bare conductor. Link to comment Share on other sites More sharing options...
Fishmanoz Posted January 31, 2022 Share Posted January 31, 2022 Hi Bob, despite John’s try on the info you’ve given us, a lot more info would help.You could start with an R catalogue number please. Also, a photo of the chassis with the body off would eliminate any doubt.You say a later motor? Earlier Panniers had X03/X04 motors, later Type 7s according the Hornby Collector Club website. But then your description matches an X04.There’s a sticky thread at the top of this forum on correctly converting an X04 (FAQ 1 in the FAQ Index). Check that out and see if it’s yours. John might be describing an abbreviated method for this conversion, but then he may instead be describing a Ringfield, I can’t tell. Link to comment Share on other sites More sharing options...
bob 340 Posted February 2, 2022 Author Share Posted February 2, 2022 hi it is type seven motor similar to the one in thomas tank with a set of pick ups on one side of the loco dont know how to load up photos up but when my daughter comes at the weekend i will ask her to do it for me regards bob Link to comment Share on other sites More sharing options...
Jim-R855 Posted February 2, 2022 Share Posted February 2, 2022 Sounds like it may be the same chassis being discussed in the class 08 diesel thread? Link to comment Share on other sites More sharing options...
