Woolf Posted April 26, 2022 Share Posted April 26, 2022 Hi I realise this is the Hornby forum, however I am hoping with a large number of enthusiasts someone may be able to help me. I am wondering whether it is possible to still obtain parts for the Mainline locos from the 80s. Many thanks Link to comment Share on other sites More sharing options...
ColinB Posted April 26, 2022 Share Posted April 26, 2022 I used Replica Railway Spares http://www.replicarailways.co.uk/. What parts do you need? In the end though all my Mainline locos were Scots or Jubilees so I replaced the chassis with Bachmann ones. Link to comment Share on other sites More sharing options...
Rana Temporia Posted April 26, 2022 Share Posted April 26, 2022 Peter’s Spares has produced some of the mid-axle insulators for the split chassis locos. There is also at least one person on eBay that is producing new 3D printed parts for some Mainline locos. Sometimes the easiest and cheapest option is a donor loco, strip it for the parts you want and sell on those that you don’t want. However you may find it a bit addictive and want to repair that….and then the next one and the next…. Link to comment Share on other sites More sharing options...
Topcat2018 Posted April 26, 2022 Share Posted April 26, 2022 Not directly related to the main topic but I've never been a fan of Bachmann split-chassis locos and wouldn't have thought of using them as a replacement. I only buy split-chassis Bachmann locos if it's something rare I find that the axles come loose from the insulated centres so the loco waddles like a duck. The chassis also wear so that the metal wheel axles no longer make contact. To remedy this I strip them down and give a thorough clean and degrease. Put brass shims in the bottom of the chassis "troughs" to re-make the contact, then glue the axles back into the centre insulators with epoxy. Link to comment Share on other sites More sharing options...
ColinB Posted April 26, 2022 Share Posted April 26, 2022 The only issue I have had with Bachmann split chassis locos is the insulators that fit between the wheel axles. You can get them new from Bachmann. I also replaced the plastic "top hat" washers that hold the two halves together. I also bought some conductive grease so that I got good electrical contact and lubrication on the wheels. I converted all of mine to DCC and they still run well, probably a lot better than my ringfield based locos, although I have sold most of these. Link to comment Share on other sites More sharing options...
Woolf Posted April 27, 2022 Author Share Posted April 27, 2022 Thank you all for help and advice, initially I was looking for a cylinder block for a Class 4, but I have a J72 that doesn't run, but not investigated the cause yet. Thanks. Link to comment Share on other sites More sharing options...
