Replacement wheels for old Mainline coaches
ColinB
Having re-wheeled several Mainline coaches I sometimes find that they do not all spin freely. Usually, it is about one in eight or ten. Oddly I cannot seem to find any reason but suspect the problem might lie with a bad combination of wheel and bogie so swapping sets around sometime fixes the problem.
If you experience a similar problem, I would recommend getting a bearing reamer.
I have found the same with all the Hornby variants of 14.1mm wheels (R8264, R8128, and R8234). However, The Bachmann 14.1mm and Bachmann are which is odd since Bachmann later made the Mainline Mk1s! so I tend to go for the Hornby ones these days.
