rughat Posted August 21, 2012 Share Posted August 21, 2012 Can any one help, Can you fit a dcc decoder to a Class 91 HSS285. iT AS A RING FIELD MOTOR WITH JUST ONE FEED FROM REAR BOGIE, VIA SWITCH ON THE OVERHEAD PLANTOGRAPH. Link to comment Share on other sites More sharing options...
Blackbird Posted August 24, 2012 Share Posted August 24, 2012 Yes. Fitting a DCC decoder to a Ringfield motor has been well covered on this forum, check 'search'. It is not recomended that you run on pantograph (overhead) supply with DCC, although it can be done with limitations and care in loco setup. Link to comment Share on other sites More sharing options...
