m0eoujohn Posted August 25, 2012 Share Posted August 25, 2012 has anyone used these point motors with rai master will they work Link to comment Share on other sites More sharing options...
Montywb Posted August 25, 2012 Share Posted August 25, 2012 Yes, I am using them with Railmaster & R8247 decoders although they do need a special bit of wiring, which I got from Richard Johnson of DCC Concepts in Australia. Monty Link to comment Share on other sites More sharing options...
Bulleidboy Posted August 25, 2012 Share Posted August 25, 2012 I think with the new digital version, the decoder is built in. I down-loaded the new instruction sheet, and you programme the point motor as you would anything else, and then just add two wires from the point motor to your bus cable. There are a couple of extras you can wire in, but in basic form just two wires and away you go. Link to comment Share on other sites More sharing options...
m0eoujohn Posted August 27, 2012 Author Share Posted August 27, 2012 bulleidboy said: I think with the new digital version, the decoder is built in. I down-loaded the new instruction sheet, and you programme the point motor as you would anything else, and then just add two wires from the point motor to your bus cable. There are a couple of extras you can wire in, but in basic form just two wires and away you go. thanks for the replies i have got the new digital ones but not had chance to try them on railmaster Link to comment Share on other sites More sharing options...
