StanierBlue Posted February 14, 2023 Share Posted February 14, 2023 Hi. Any advice welcomed please. Hornby Crosti 9F, TTS fitted. has stopped moving but the sound works correctly, accelerates etc whistles et al. I've fitted a new sound decoder, exactly the same outcome. Tried a reset, to no avail. I can see examples and potential CV programming solutions on USA websites, brakes locked etc, but nothing so far for Hornby TTS. Any shared experience/ advice would be most welcome. Thanks in anticipation Link to comment Share on other sites More sharing options...
RDS Posted February 14, 2023 Share Posted February 14, 2023 @robert (Posted - 10:34 14/2/23)Whilst you wait for an answer:Moderator Note:It is in your own interest to have a unique user name. Could you please select ‘My Account’ towards the top right hand corner of your screen, then Community and choose a nickname in the ‘My Profile' tab, rather than your First name that has been automatically allocated by the system. We had hoped a Forum change was coming to prevent this automatic allocation but a manual change is required at the moment and there will be more than one member with your name. This request together with some other information for new posters is contained in a thread at the top of the General Discussion section called ‘Information for new members registering for the Forum’More details here Link to comment Share on other sites More sharing options...
P-Henny Posted February 14, 2023 Share Posted February 14, 2023 If it previously moved and now stopped plus sound working and a new decoder still has the same symptoms.Then this proves pickups are working and decoder is probably not the fault, leaving only the motor itself or the wiring from the DCC decoder socket to the motor. The motor connects to pins 1 & 5 on the 8 pin DCC socket.Very unlikely to be CV issue if the motor previously worked and has just stopped.You ideally need to use a Multimeter to diagnose the wiring further. You can confirm the motor as good or bad by taking two wires from a DC power source and placing them directly on the motor terminals. Unplug the decoder first to eliminate the risk of the DC supply damaging the motor control H bridge circuit in the decoder. Link to comment Share on other sites More sharing options...
96RAF Posted February 14, 2023 Share Posted February 14, 2023 I agree with P-H in that your symptoms rule out the decoder, so the loco wiring is where the trouble lies. Multi-meter and point to point wiring checks within the loco required. Link to comment Share on other sites More sharing options...
ColinB Posted February 16, 2023 Share Posted February 16, 2023 It is in cases like this that you remove the decoder replace it with a DC header and then check if the loco runs on DC. You also won't blow anything up if you do your testing on dc which you could easily do on DCC if you are playing with motor connections. Link to comment Share on other sites More sharing options...
StanierBlue Posted March 2, 2023 Author Share Posted March 2, 2023 Moderator - acknowledged and actioned.First and foremost a big thank you for the time taken in responding to my crie de cour the matter was frustrating the proverbial out of me. Following the various advice provided I undertook a detailed check of the loco and eventually discovered two very small cracks on the wiring between the loco and tender. Of the four wires the two central ones had the tiny cracks whereas the two outer ones were undamaged. The loco would thereby accelerate etc sound wise as the power was increased but wouldn't move. I've no idea how or what caused the issue, no obvious heat or impact damage, may just be stress breakage, but at least my sanity is back intact as to the cause. So thanks again all. Link to comment Share on other sites More sharing options...
96RAF Posted March 2, 2023 Share Posted March 2, 2023 If the breaks in the wiring are in the four pin plug wiring then that part is available as a spare X6113 from memory (others will correct me if not) and it is easier to replace that than trying to fettle wire breaks within insulation.PN edited - thanks P-H Link to comment Share on other sites More sharing options...
P-Henny Posted March 2, 2023 Share Posted March 2, 2023 X6113 Link to comment Share on other sites More sharing options...
StanierBlue Posted March 2, 2023 Author Share Posted March 2, 2023 X6113 understood. That sounds like the way forward. Many thanks again. Link to comment Share on other sites More sharing options...
P-Henny Posted March 2, 2023 Share Posted March 2, 2023 Of the four wires the two central ones had the tiny cracks whereas the two outer ones were undamaged. The two inner central ones transfer power from the decoder to the motor. So that would be consistent with sound working but no motor function. Link to comment Share on other sites More sharing options...
StanierBlue Posted March 3, 2023 Author Share Posted March 3, 2023 Thanks PH and yes that was/is the case. The wire issue was very difficult to spot but once found the 'mystery' was solved. Link to comment Share on other sites More sharing options...
