DaveH Posted September 8, 2012 Share Posted September 8, 2012 Purchased a DCC ready Pendalino set R1134. Reading instructions supplied to fit a decoder, "Remove the chasis screws as shown. The body will lift off easily". Problem, I can't see any screws to remove as show in the diagram. Anybody with any infomation? I've checked the service which does not show the screws. Link to comment Share on other sites More sharing options...
Rog RJ Posted September 8, 2012 Share Posted September 8, 2012 There are no screws that need removing. What you need to do is ease the body work away from the chassis with a thumbnail and insert small pieces of card to prevent the body slipping back into place and then lift the body off the chassis. Link to comment Share on other sites More sharing options...
DaveH Posted September 9, 2012 Author Share Posted September 9, 2012 Thanks, wasn't sure if there was any little tricks to the Pendalino. Body eased off with out any problems but raised a new question. As this is my first decoder fitting I expected to find the 8 pin socket which is described, nothing was found. So either they have put the wrong motor unit in a DCC Ready box or I have to splice the wires into the original. Hornby support will be contacted Monday. Link to comment Share on other sites More sharing options...
Rog RJ Posted September 9, 2012 Share Posted September 9, 2012 The 8 pin socket will have a blanking plug fitted to allow the model to run on a dc (analogue) system. You will need to remove the blanking plug (1 in the powered car and 1 in the dummy power car) to allow a decoder to be fitted. This service sheet https://www.hornby.com/FileLibrary/Files/Download/?FileID=85 shows the blanking plug as part number 12. Link to comment Share on other sites More sharing options...
DaveH Posted September 10, 2012 Author Share Posted September 10, 2012 Got it, the in box infomation sheet is totally different to the actual model. I located the 8 pin socket on opening up the first time but was not sure if that was meant to be like that. Now having fun fitting it. Link to comment Share on other sites More sharing options...
