John-355888 Posted May 10, 2023 Posted May 10, 2023 I installed my HM 7000 8TXS without any problems, it worked fine on bluetooth and DCC (hornby Elite) but today it only works on DCC when I switch to Bluetooth nothing will happen, any help please?
96RAF Posted May 10, 2023 Posted May 10, 2023 Scroll down the page to find the same problem posted as well as the same problem reversed.
LTSR_NSE Posted May 10, 2023 Posted May 10, 2023 The potential solutions previously mentioned have been either:• write value 8 to CV8 to reset all CVsor• delete decoder from app (may need to do this 3 times & force delete if decoder is completely unresponsive in app) & then re-link using decoder reset code.
Fishmanoz Posted May 10, 2023 Posted May 10, 2023 Mods, title please - delete “problem” and insert “not Working on Bluetooth”.
brom Posted May 14, 2023 Posted May 14, 2023 I had a similar issue with some of mine the other day.I’ve got 5 hm7000 decoders fitted and all working fine last Tuesday the app connected to all 5 next day would only connect to one so had to reset cv8 to get them to operate on Dcc and they all worked and sounded fine,still bugged me no blutooth control so I unassigned the decoders from the locos deleted the decoders then re linked them I didn’t have to use any reset code.Anyway all working fine now just seemed strange for them to do that.Is there a cv that controls the blutooth operation to turn it off or on in case it happens again without having to delete and relink the decoder?
P-Henny Posted May 14, 2023 Posted May 14, 2023 Is there a cv that controls the bluetooth operation to turn it off or on in case it happens again without having to delete and relink the decoder? Read Page 48 of the manual with reference to CV12.Edit: RAF posted whilst I was busy looking up the Page number
brom Posted May 14, 2023 Posted May 14, 2023 Yep many thanks was just reading the manual and saw cv 12 range 0-2
96RAF Posted May 14, 2023 Posted May 14, 2023 Note that when amending CVs they may not refresh upon synch depending upon upon where the CV was changed, app or controller. This is a known occasional glitch and it is best to check both in the app and from the Elite on a programming track read-back what the actual values are if you are having problems. A bit of a pest admitted but a definite way of confirming a change has stuck.Often a power cycle of the decoder will put things right.
