Anthony-355891 Posted May 16, 2023 Share Posted May 16, 2023 My Railroad TTS Class 40 automatically goes to F1 engine start up sound when power is applied to the track (mains switched on) or engine is placed on a live track. Power is from Select at firmware 1.6 which is connected to the track using a dcc removable power clip. This is the case on programming track or running track which is a simple loop.It also has an intermittent response to other F functions and usually ends up completely unresponsive even after several successful circuits of my running track. No error codes shown. The only way to get a response is to power off and/or remove loco from the track. TIA Link to comment Share on other sites More sharing options...
96RAF Posted May 17, 2023 Share Posted May 17, 2023 Likely F1 has been left on.Reset both the Select and the TTS decoder. Link to comment Share on other sites More sharing options...
