Ged_K Posted May 23, 2023 Share Posted May 23, 2023 Of analog train controllers (beyond the old tried and tested rheostat or variable transformer type) what is the preferred electronic variety, thyristor, transistor, feed-back (Wheatstone-bridge) or the more recent Pulse-Width-Modulation (PWM) types? Link to comment Share on other sites More sharing options...
JJ73 Posted May 23, 2023 Share Posted May 23, 2023 HiyaNot sure if mine falls under your list, but I use a H & M Duette!!! 🙂🚂 Link to comment Share on other sites More sharing options...
Rog RJ Posted May 23, 2023 Share Posted May 23, 2023 It depends what locos you are running. Link to comment Share on other sites More sharing options...
Rana Temporia Posted May 23, 2023 Share Posted May 23, 2023 All work and have certain advantages/disadvantages when comparing them. For the old locos I use I have found PWM controllers to be the best coupled to a suitably adequate power supply. Budget Model Railways used to produce a box for around £5 that a standard circuit would just clip into. (Total cost including box, circuit and power supply <£10). I have made a few now and can recommend them but I think BMR have dropped the box from their range and moved onto eBay. The old H&M are superb and there is nothing wrong with the old Tri-ang controllers, I have a few and still use them with no problems but I would get it tested if you buy a S/H one. I bought an H&M clipper once that sent mains voltage down the track wires and some of the older electronic devices may contain asbestos insulation. Link to comment Share on other sites More sharing options...
ModelerXYZ Posted May 23, 2023 Share Posted May 23, 2023 My HM2000 serves me well.XYZ Link to comment Share on other sites More sharing options...
