Daniel-358007 Posted June 7, 2023 Share Posted June 7, 2023 I am trying to replace the rubber tyres on the center axle. How do I remove the connecting rods as there are no screws attached to the wheel? Thank you. Link to comment Share on other sites More sharing options...
atom3624 Posted June 7, 2023 Share Posted June 7, 2023 Do the pins rotate in holes in the coupling rods?Others will confirm, I'm just surmising, perhaps the pins are 'friction fit' - push in, pull out?Al. Link to comment Share on other sites More sharing options...
Going Spare Posted June 7, 2023 Share Posted June 7, 2023 As Al says, the rods are pinned to the wheels and the pins can usually be gently levered or pulled out quite easily. Link to comment Share on other sites More sharing options...
ntpntpntp Posted June 7, 2023 Share Posted June 7, 2023 Unless the coupling rod pins are obviously threaded (in which case they'll have a screw slot or a hex head) I use a craft knife behind the rod and pin to gently ease the pin from the wheel. Do this within a large clear plastic bag to catch the pin if/when it pings off! Link to comment Share on other sites More sharing options...
Daniel-358007 Posted June 7, 2023 Author Share Posted June 7, 2023 Dear All. Thank you for your helpful replies. You are all correct. The pins can be eased out easily and pressed fit back. I have learnt something new today. Thank you again. Link to comment Share on other sites More sharing options...
