Bluetooth is the future
Steve-353799
Yes Blunami has been out for a while.
My concern is incompatibility: as I understand it you can't run Blunami decoders with the HM7000 app and v.v? This kind of goes against the openness of traditional NMRA DCC where at the track protocol level any controller can run any decoder.
Hornby HM7K app does not pick up Blunami decoders and the Blunami app does not pick up Hornby decoders, this is likely because there is no written standard for Bluetooth application to model railways like there is a DCC standard. Until someone standardises the standard in use then ‘ne’er the twain shall meet’
Lack of a Bluetooth standard is also an issue some of the ‘critics’ failed to appreciate when shouting about decoder sizes.
Currently there are only dimension specifications for non sound and sound versions of decoders listed by NMRA and NEM… they haven’t caught up to Bluetooth yet and it would have to be bigger due to extra components and the antenna.
Will be interesting to see which system wins out as the standard.
I think Betamax will win it hands down joy
Provided the issues of HM7000 BT will be straightened out within reasonable time, it sure will be a step forward in control. AFAIK there's no decoder around offering DCC and BT with such a small footprint. If they could be persuaded to offer it with a Hirose connector instead of a PCB antenna, some 12mm could be saved in length.
The examples of Hirose BT connectors are huge. The current plan is to reduce PCB size by use of smaller components and cross board Ae within the smaller footprint.
@96RAF
Don't know what connectors you are referring to. Here's a picture of the antenna section on a WiFi transceiver I used ( bought it for ~ 2$ apiece ). It uses an onboard antenna and alternatively you can plug in a ready made wire antenna into the socket.
Compare the size to the clumsy affair of HM7000. There's potential to reduce the size considerably with an almost neglectable increase in component cost.
I’m sure the Hornby decoder designers know what they are doing and will use the most appropriate Bluetooth components available for the gen-2 task. Adding even pennies to the price is always a big consideration.
Recently one of the social media ‘in the know experts’ had suggested that as there were no in-stock decoders of a certain pin type it likely meant there was a shipping container of the smaller next gen-2 decoders on its way. The irony being the decoders in short supply were not the oversize ones and how many decoders can you get in a 40 ft container - enough to last a lifetime I reckon.
