Has anyone managed to get TT120 semaphore signals
Steve-353799
Hello gang I have had a good look around but TT120 semaphore signals seem to be somewhat of a rarity. Has anyone been able to source any?
Also, some have said that the Dapol N gauge semaphores are pretty generous and are a good fit scale wise.
Would anyone be able to confirm this?
Thanks
Steve
Just come across this on some dimensions regards semaphore signals.
Also, the Dapol N gauge signal is 52mm tall so on my reckoning 52x120= 6240. Just over 20 feet tall. So, the Dapol signal should be in the ball park me thinks? If you wanted to make it a little taller, I suppose you could always put it on a 2/3mm plinth.
"That information seems to be quite hard to find on the net, so I dug out my copy of Derek Mundy's Signals for the Railway Modeller, and while there are no definitive numbers, here are a few random dimensional quotes and figures...
- height from rail to signal - 15' to 35' (SR)
- signal always at or above the driver's eye height
- spacing between two signals on same mast - 6' (4' for calling on or smaller arm)
- signal arm usually 1'6" from top of post (not counting the finial)
- black paint line 4' from ground level
- lattice post (LSWR, SECR, NBR) - 20' to 60' tall
- table of standard lengths of tubular post (no specified company) - 17', 19', 21', 24', 26', 29', 31', 34', 36' (plus a few inches here and there)
- bracket signal, minimum spacing between dolls - 6'6" (10' for parallel running lines)
- various references to a 4' arm (the coloured bit, not including the black spectacle plate) or 2' calling-on arm
- the 10" wide white stripe being 11" back from the end of the arm on a home signal
- the 8" wide chevron on a distant being 12" back from the edge
Then, in Railway Signal Engineering (Mechanical) by Lewis, 1932...
- "Some companies had the sizes of wooden arms made proportional to the height of the post..."
- as a rule, arms on brackets were made shorter than on single posts to keep the brackets as short as possible
- standard lengths of wooden signal arms, centre of signal post to tip of arm...
 - main line 5'0" x 12" or 4'6" x 10"
 - main line to goods line 4'0" x 12" or 3'6" x 10"
 - main line to siding 3'0" x 9" or 2'0" x 6"
 - sidings 2'6" x 8" or 2'0" x 6"
Measuring a couple of Ratio and MSE signal arms on mine, the coloured portion of the main arms is 4' plus another 6"-12" or so of black to the centre of the post, or 3' for backing/siding signals."
