wagonmaster Posted August 18, 2023 Share Posted August 18, 2023 some how wire loose on loco any idea where it has broken away from Link to comment Share on other sites More sharing options...
RDS Posted August 18, 2023 Share Posted August 18, 2023 RDS Mod NoteI have rejected the 3 duplicate posts you submitted against this thread. Please note that pictures are always sent for approval, so do not appear instantly.Hopefully, someone will be able to answer your question. Link to comment Share on other sites More sharing options...
ColinB Posted August 18, 2023 Share Posted August 18, 2023 Looking at the photos it should be connected to the motor terminal underneath the one with the red wire on. If you look at the second photo you can see the motor terminal with no wire on, plus the capacitor goes across the motor terminals, so the red wire goes to one terminal the black wire to the other. Link to comment Share on other sites More sharing options...
96RAF Posted August 19, 2023 Share Posted August 19, 2023 To illustrate Colin’s answer Link to comment Share on other sites More sharing options...
ColinB Posted August 19, 2023 Share Posted August 19, 2023 Thanks 96RAF. I should also warn not to put too much solder on the joint as it is very near the chassis. Link to comment Share on other sites More sharing options...
