Aussie Fred Posted August 31, 2023 Share Posted August 31, 2023 I seem to remember somewhere where it was discussed about Hornby carriages with lights fitted, but can't remember if the lights work off a battery or from the track, and if a battery, is it easily accessable. Link to comment Share on other sites More sharing options...
96RAF Posted August 31, 2023 Share Posted August 31, 2023 Depends which coaches you are talking about, Pullmans were track powered but the smaller Maglight coaches had batteries, at least the retro-fit kits did . . . https://uk.hornby.com/products/maglight-lighting-unit-mk3-coaches-r7305 Link to comment Share on other sites More sharing options...
Bulleidboy Posted August 31, 2023 Share Posted August 31, 2023 Hornby did produce a range of Mk1 coaches with track powered lights fitted. These coaches were available in Autumn 2017.R4607 BR SR Mk1 Composite Coach S15027 R4609 BR SR Mk1 Corridor Brake Coach S34239 R4609A BR SR Mk1 Corridor Brake Coach S34240R4714 BR Mk1 Corridor 2nd Class Coach M24912R4715 BR Mk1 Corridor Composite Coach M15679 R4716 BR Mk1 Corridor Brake 2nd – M34672 Link to comment Share on other sites More sharing options...
Aussie Fred Posted August 31, 2023 Author Share Posted August 31, 2023 Depends which coaches you are talking about, Pullmans were track powered but the smaller Maglight coaches had batteries, at least the retro-fit kits did . . . https://uk.hornby.com/products/maglight-lighting-unit-mk3-coaches-r7305 They are the 4 wheel Era 2 that are on special from the Hornby store e.g:Hornby LSWR, 4 Wheel Coach, 3rd Class, Fitted Lights, 302 - Era 2 I tried to order them but they wouldn't send them to Australia because they are classified "hazardous", which could be because of the batteries. I thought it might have been another SMS issue. I asked about "slow mail' - by sea, but they wouldn't even consider it.Still wondering about the SMS issue though. Link to comment Share on other sites More sharing options...
Brew Man Posted August 31, 2023 Share Posted August 31, 2023 I have the Hatton's versions of SECR and SR 4 and 6 wheel coaches. They are meant to have pickups and decoders fitted to each coach for lighting but I've fitted Hornby Maglights instead. They work very well and are cheaper than fitting a decoder to each and every coach. Link to comment Share on other sites More sharing options...
Aussie Fred Posted September 14, 2023 Author Share Posted September 14, 2023 Just an update, I have recieved my full rack of coaches, LSWR, 4 Wheel Coaches, fitted lights, era 2, supplied by a UK shop - they had no problems sending them by air and recieved in perfect condition. They cost about A$20 more each than Hornby were selling them for, but postage free. On the other side of the ledger, they were $30 each cheaper than buying them here in Australia, although at the Aussie price, I probably would not have bought them.Makes me wonder again whether it was a freight problem or SMS. Link to comment Share on other sites More sharing options...
81F Posted September 15, 2023 Share Posted September 15, 2023 @Brew Man,You do realize that you only need the decoder to switch the lights off and on? So you do not need a decoder if you are happy to run the lights on all the time. Link to comment Share on other sites More sharing options...
ColinB Posted September 15, 2023 Share Posted September 15, 2023 If you do need a decoder I just use those cheap LaisDCC ones. I also have a set of Coronation coaches and Virgin coaches made by Hornby with lights that stay on all the time. Link to comment Share on other sites More sharing options...
Brew Man Posted September 15, 2023 Share Posted September 15, 2023 @Brew Man,You do realize that you only need the decoder to switch the lights off and on? So you do not need a decoder if you are happy to run the lights on all the time. Yes, I do realise that, but I would want them switchable Link to comment Share on other sites More sharing options...
Brew Man Posted September 15, 2023 Share Posted September 15, 2023 If you do need a decoder I just use those cheap LaisDCC ones. I also have a set of Coronation coaches and Virgin coaches made by Hornby with lights that stay on all the time. Still works out quite expensive at, I think around £15 of so each. Then there is the wheel drag to consider. Link to comment Share on other sites More sharing options...
