Wullie1707822452 Posted September 1, 2023 Share Posted September 1, 2023 I am trying to setup 8 pin TXS Decoder with a class 66 sound file but I can,t get any sound. train runs back & forward ok but no sound.I have tried reseting unteen times. But no joy.Any advice would be very grateful. cheers willie Link to comment Share on other sites More sharing options...
SteveM6 Posted September 1, 2023 Share Posted September 1, 2023 First advice is to work through the troubleshooting guides - the links are at the top of the forum.The 66 is the largest file currently available and will show up any deficiencies in your setup - try loading the 08, which is the smallest file, to test you are following the correct process. Link to comment Share on other sites More sharing options...
Ighten 1707822464 Posted September 2, 2023 Share Posted September 2, 2023 If you watch the loading screen when you download it when it gets to the 2nd part when does it give up. And does your connection go red Link to comment Share on other sites More sharing options...
P-Henny Posted September 2, 2023 Share Posted September 2, 2023 I seem to recall the 66 sound file loading issue being raised before in forum, so it does seem to be a problematic one.As others have said work through the published 'Troubleshooting Guide' listed on the following page.https://uk.hornby.com/hm7000/hm-dcc-guides Link to comment Share on other sites More sharing options...
96RAF Posted September 2, 2023 Share Posted September 2, 2023 I have the 66 profile loaded and cannot remember having any problems with it. Link to comment Share on other sites More sharing options...
Wullie1707822452 Posted September 2, 2023 Author Share Posted September 2, 2023 Thank you for getting back to me.I have tried to load the class 08 train runs ok but still no sound. I have tried the speaker in another HM7000 train I have & it works ok.When you go into manage Device all is Green no errors. Profiles 08 & 66 seem to load up with no faults Bluetooth blue on all the time. Tried Unlinking Deleting Device & relinking again.I have loaded 3 other trains one is a 66 with HM7000 & working ok.Many thanks for all your Help, Cheers Willie Link to comment Share on other sites More sharing options...
96RAF Posted September 2, 2023 Share Posted September 2, 2023 I guess then after going thru’ all the processes that the decoder sound is duff, unless the volume slider has been set to off in error, although installing a new profile would have set volume to default level.If it is duff contact Hornby and ask for a replacement, telling them which profile you want. Link to comment Share on other sites More sharing options...
Wullie1707822452 Posted September 26, 2023 Author Share Posted September 26, 2023 I thank you all for help. Got replacement decoder, reloaded profile 66 & all is well tooting away happily. Many thanks. Cheers Willie Link to comment Share on other sites More sharing options...
RDS Posted September 26, 2023 Share Posted September 26, 2023 I thank you all for help. Got replacement decoder, reloaded profile 66 & all is well tooting away happily. Many thanks. Cheers Willie Thanks for the feedback of your Decoder being sorted. Lots don't! Link to comment Share on other sites More sharing options...
Bulleidboy Posted September 26, 2023 Share Posted September 26, 2023 Sorry to hijack this thread, but this might be helpful. I fitted a Power Bank to my KC3 Class 66 yesterday. It was easier to remove the TXS Decoder to plug in the power bank. When replacing the decoder it appeared to be a very sloppy fit (loose), the result being I had perfect sound but no movement. I noticed that the decoder was at a slight angle when fitted, so placed a small piece of folded card between the end of the decoder and the chassis under the decoder, there was just enough tension in the card to hold the decoder horizontal and everything worked fine. It might be possible to bend the pins so that there was more tension in the connection when fitting the decoder, but did not want to risk doing any damage so did not do this. Link to comment Share on other sites More sharing options...
ColinB Posted September 26, 2023 Share Posted September 26, 2023 I pointed this out when these devices first came out, I fitted it to a Queen Elizabeth, yes that mega expensive one (well not to me) it was the only 21 pin loco I had. The screws holding my 21 PCB with the socket on, were round headed ones, I replaced them with countersunk ones and the 21 decoder, although not perfect sits better. Now on a P2 which I eventually moved the TXS decoder to, the decoder is upside down so the connector is not an issue. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 26, 2023 Share Posted September 26, 2023 I remember your posting that Colin.Mods, sounds like one for feeding back to Hornby. If they are going to use hi-tech plugs and sockets, they need to work without bits of Lo-tech cardboard to support them, or having to replace mounting screws. Or they could put cardboard and screws in the box!? Everything else is in there. Link to comment Share on other sites More sharing options...
96RAF Posted September 26, 2023 Share Posted September 26, 2023 They know about the 21-pin problem Colin had Fishy, but not much you can do about retro fettling stuff already out the door. The OP is having problems with an 8-pin, likely due to poor tolerance of fit twixt pins and socket. I have squeezed the banks of plug pins towards each other just a tad to make it grip better. Link to comment Share on other sites More sharing options...
Fishmanoz Posted September 27, 2023 Share Posted September 27, 2023 Rob, Colin’s comment was in response to BB putting cardboard under the decoder in a KC3 Class 66, not the OP’s 8-pin.What socket does the KC3 have? Same as OP’s Class 66 or different. From BB’s description, sounds like N18 or 21-pin. Link to comment Share on other sites More sharing options...
