Michael Thomas-366660 Posted September 12, 2023 Share Posted September 12, 2023 My Excalibur Express loco, which ive had for several+ years sitting in a box barely runs on the track, Makes a noise while trying to move then stops.. When i wiggle it it moves slightly. Any Advice please? do i need to send it to hornby for a service/repair? Link to comment Share on other sites More sharing options...
96RAF Posted September 12, 2023 Share Posted September 12, 2023 All the lubrication will have dried out so it should be given a service, clean off old oil and grease and lubricate very sparingly per the maintenance sheet if you have one, else generic lubrication using common sense.A tiny drop on the motor bearing, axle bearings, valve gear and motion linkage pivots, rolling stock and tender axles, etc.Note to use the correct lubricants, not household oil like 3-in-1 or WD-40, etc. Special model lubricants or sewing machine or clock oil are ideal, but do not overdo it. Too much is as bad as none at all. Link to comment Share on other sites More sharing options...
P-Henny Posted September 12, 2023 Share Posted September 12, 2023 See also:FAQ1 located in the 'General Discussion FAQ Index' pinned sticky thread. Direct link below will take you there.https://uk.hornby.com/community/forum/faq-beginner-question-my-loco-or-set-is-not-working Link to comment Share on other sites More sharing options...
ColinB Posted September 12, 2023 Share Posted September 12, 2023 Probably the wheels have oxide on them, give them a clean with alcohol/ink rubber/cotton wool bud and see if it runs any better. Long term give the loco a service but generally in most of my cases it is the wheels. From a quick web search (Sam did a review on it) it is relatively new loco, I can't remember what mechanism Hornby implemented for the pickups. On a lot of the older locos the pickup connection relies on two press fit connections on the pickup plate, sometimes the oil runs down and gets into these connections giving a very poor connection. Try the wheels first. Link to comment Share on other sites More sharing options...
