pacman849 Posted October 10, 2012 Share Posted October 10, 2012 Hi, Sorry if this has been raised already, but I cannot see anything in the forum that addresses this. A couple of my Railmaster controlled points do not change their Blue Direction Indicators in my plan when I change the point using the Red and Green buttons. The point changes okay, and the appropriate Red or Green button lights up, however the Blue Direction Indicator line on the point does not move. This is happening on a couple of my points and I cannot fathom what is causing it to happen. Does anyone else have experience of this issue? Cheers. Link to comment Share on other sites More sharing options...
tsclass87 Posted October 10, 2012 Share Posted October 10, 2012 i have some designs whereby the points blue direction indicator is not visible at all. do not know why. Link to comment Share on other sites More sharing options...
LMSTim Posted October 11, 2012 Share Posted October 11, 2012 Why not send a Help Request to Hornby support from within RailMaster and explain the problem in the message field. That way they can also see your plan (it's sent with the request) and sort it out for you. Link to comment Share on other sites More sharing options...
St1ngr4y Posted October 11, 2012 Share Posted October 11, 2012 pacman849 said: Hi, Sorry if this has been raised already, but I cannot see anything in the forum that addresses this. A couple of my Railmaster controlled points do not change their Blue Direction Indicators in my plan when I change the point using the Red and Green buttons. The point changes okay, and the appropriate Red or Green button lights up, however the Blue Direction Indicator line on the point does not move. This is happening on a couple of my points and I cannot fathom what is causing it to happen. Does anyone else have experience of this issue? Cheers. Load up your plan in the layout designer and move the point in question, just to make sure you haven't accidentally placed two points in the same square one on top of the other. Do the same with the red/green buttons. Ray Link to comment Share on other sites More sharing options...
