Photogreycat Posted October 30, 2023 Share Posted October 30, 2023 Loading a profile results in an error saying motor overload.Repeating the process and resetting the decoder does not cure the problem.Interestingly is that the sounds work but no power is delivered to the motor.Does anyone know how to fix this.John Link to comment Share on other sites More sharing options...
ColinB Posted October 30, 2023 Share Posted October 30, 2023 I suppose the first question is "have you tried loading another profile" to see if the error is with the file or your motor connections. Link to comment Share on other sites More sharing options...
96RAF Posted October 30, 2023 Share Posted October 30, 2023 Which profile is it.The problem has been seen before and sorted by procedure. See previous posts about it. Link to comment Share on other sites More sharing options...
Photogreycat Posted October 31, 2023 Author Share Posted October 31, 2023 Tried different profiles and the problem is the same. Link to comment Share on other sites More sharing options...
SteveM6 Posted October 31, 2023 Share Posted October 31, 2023 As Rob said, the solution has been documented on the forum already.Power everything off - tablet, phone, layout, programme track - everything.Then switch it all back on again. Link to comment Share on other sites More sharing options...
