Christopher-371583 Posted November 3, 2023 Share Posted November 3, 2023 Just received my scotsman TT120 set and have set up following all the instructions, motion works as expected through the app but there is no sound. The loco has made sound a couple of times randomly, but that's it.Things I have tried so far are unlinking and resetting with the code, using a different device, importing latest profile etc. Anything else I can try or am missing about how to work the sound functionality before I contact Hornby and return it for a replacement? Link to comment Share on other sites More sharing options...
ColinB Posted November 3, 2023 Share Posted November 3, 2023 Well I have just sent mine back for exactly the same issue. ~You need to do the standard things like do a reset on it ( write 5 for sound or 8 to cv 8 if you didn't know), because Hornby will ask you that. I suppose if you are using the plug in speaker, check that is plugged in fully. Funny that it works occasionally, mine failed completely. Link to comment Share on other sites More sharing options...
Rallymatt Posted November 3, 2023 Share Posted November 3, 2023 You may have already done this but worth checking. Make sure you unassign the loco/decoder, then unlink, delete the loco from the engine shed, power everything down, the loco and the device running the app. Then restart and start again. I presume you did turn the sound on via function 1? This has been overlooked before, you can still get random sounds without the sound being activated. Hope this helps Link to comment Share on other sites More sharing options...
Rallymatt Posted November 4, 2023 Share Posted November 4, 2023 Just to add to this, there was a reported instance where the fitted speaker in TT:120 pacific was very quiet. The speaker contacts the underside of the PCB that holds the decoder via spring loaded contacts, not a wire. If you feel confident, it’s just careful removal of tender body (in the loco instructions) unscrew the PCB, check the contacts are correctly aligned/clean. Obviously if there is an issue or after trying the ‘at home’ things with decoder settings it’s still not working, quick call to Customer Services to get a returns number, Hornby has excellent people on the job 👍 Link to comment Share on other sites More sharing options...
Ian-372044 Posted November 8, 2023 Share Posted November 8, 2023 Interesting. I have just received The Scotsman set and there is no sound. I will have a look at your solution. Link to comment Share on other sites More sharing options...
ColinB Posted November 9, 2023 Share Posted November 9, 2023 I have to agree with you Rallymatt, sent mine away on Wednesday of last week, it was back by Saturday, really excellent service. Link to comment Share on other sites More sharing options...
LTSR_NSE Posted November 9, 2023 Share Posted November 9, 2023 @IAN is your Scotsman set analogue or TXS fitted?I believe the analogue sets don’t come with pre-fitted speakers & you need to connect the one supplied with decoder (& install it in the enclosure underneath PCB yourself.)Whereas the separately sold locos & TXS fitted sets should all have speakers pre-fitted. Link to comment Share on other sites More sharing options...
Ian-372044 Posted November 13, 2023 Share Posted November 13, 2023 TXS sound fitted. I will have another go first before I contact Hornby. It may be something simple but I deleted the profile and restarted and no difference. Link to comment Share on other sites More sharing options...
96RAF Posted November 13, 2023 Share Posted November 13, 2023 Do the speaker check to make sure the contacts are making good. Link to comment Share on other sites More sharing options...
Rallymatt Posted November 14, 2023 Share Posted November 14, 2023 A couple of settings to check, apologies if they sound obvious but these things have been overlooked before. Ensure that Function 1 is activated, it turns the sound profiles on. Check the Global sound volume, I find 20 quite loud enough, if it has somehow set to 0 that will effectively be off irrespective of Function 1 Link to comment Share on other sites More sharing options...
