Paul-372172 Posted November 9, 2023 Share Posted November 9, 2023 I have a Hornby class 08 which was fitted with TTS dcc sound. The decoder has blown so I have fitted a new R7322 HM7000-21TXS and Power Bank. The locomotive runs ok (ish) and the sound works ok but the Power Bank fails to charge even after it has been running for 15 minutes or so. Any ideas? Link to comment Share on other sites More sharing options...
RDS Posted November 10, 2023 Share Posted November 10, 2023 Hi Paul and Welcome to the ForumWhen you say the previous Decoder has blown. What were the circumstances of that. Is it a Loco fault. You say the Loco runs OK (ish), which suggests there is a problem. I have Power Banks fitted to 2 Class 08 Loco's and they start to charge immediately power is applied. Link to comment Share on other sites More sharing options...
SteveM6 Posted November 10, 2023 Share Posted November 10, 2023 As RDS suggests, this sounds like a problem with the loco rather than the decoder. Do you have another loco that you can put this decoder in to see if it works ok in there?Also make sure the PB is fully plugged in (don't push too hard or you may damage the plug on the decoder).Have you loaded the latest version of the sound file? Version 2, with changes to the PB charging protocols, is now available on the app.With the decoder removed, sort out the running issues of the loco on DC if possible before installing a decoder. Link to comment Share on other sites More sharing options...
96RAF Posted November 10, 2023 Share Posted November 10, 2023 How do you know it’s not charging? Link to comment Share on other sites More sharing options...
P-Henny Posted November 10, 2023 Share Posted November 10, 2023 If your answer to 96RAF's question is because the loco keeps stopping (or something similar) then you might consider there is an intermittent fault in the motor or motor circuit that gives the impression that there is no charge in the power bank.Hence the need to do as others have suggested .... test the loco as an Analogue loco (decoder removed) on DC. If the running issues still persist, then it cannot be a decoder / power bank issue. Link to comment Share on other sites More sharing options...
ColinB Posted November 10, 2023 Share Posted November 10, 2023 Have you done the test where you pull it off the track while it is running and see if it continues to run? Link to comment Share on other sites More sharing options...
