m0eoujohn Posted October 20, 2012 Share Posted October 20, 2012 why cant i change the id of this loco it is factory set on 3 only Link to comment Share on other sites More sharing options...
2e0dtoeric Posted October 20, 2012 Share Posted October 20, 2012 Another radio ham?? (I'm now m0hff) All new DCC loco's and chips are set to the default of 0003. What controller are you using? Have you put the loco you want to programme onto a separate programming track, and connected the track to the programme output of the controller? Link to comment Share on other sites More sharing options...
m0eoujohn Posted October 20, 2012 Author Share Posted October 20, 2012 2e0dtoeric said: Another radio ham?? (I'm now m0hff) All new DCC loco's and chips are set to the default of 0003. What controller are you using? Have you put the loco you want to programme onto a separate programming track, and connected the track to the programme output of the controller? Link to comment Share on other sites More sharing options...
m0eoujohn Posted October 20, 2012 Author Share Posted October 20, 2012 well done on the new call i am using an ilete system and tried both prog and track but no joy all the others program first time Link to comment Share on other sites More sharing options...
m0eoujohn Posted October 20, 2012 Author Share Posted October 20, 2012 sorry elite unit Link to comment Share on other sites More sharing options...
2e0dtoeric Posted October 20, 2012 Share Posted October 20, 2012 Will the loco run using the 003 setting? Does the Elite even recognize the loco id? Do you have other DCC locos on the track that have been reset? Is it a DCC READY or DCC fitted loco (easy mistake to make!) If it's a ready, there's no chip installed, just a blanking plate! It could be you have chosen a dirty bit of track, or the loco wheels need cleaning, before the Elite will recognize the on-board chip. They can be very fussy. If the loco will run in the default setting, let it circulate the track for a few minutes, to give all the pick-ups and wheels a polish, then try again. Link to comment Share on other sites More sharing options...
m0eoujohn Posted October 22, 2012 Author Share Posted October 22, 2012 2e0dtoeric said:yes it is recognized and runs better thaqn all the others and very very slow Will the loco run using the 003 setting? Does the Elite even recognize the loco id? Do you have other DCC locos on the track that have been reset? Is it a DCC READY or DCC fitted loco (easy mistake to make!) If it's a ready, there's no chip installed, just a blanking plate! It could be you have chosen a dirty bit of track, or the loco wheels need cleaning, before the Elite will recognize the on-board chip. They can be very fussy. If the loco will run in the default setting, let it circulate the track for a few minutes, to give all the pick-ups and wheels a polish, then try again. Link to comment Share on other sites More sharing options...
m0eoujohn Posted October 22, 2012 Author Share Posted October 22, 2012 m0eoujohn said:yes it runs great 2e0dtoeric said:yes it is recognized and runs better thaqn all the others and very very slow Will the loco run using the 003 setting? Does the Elite even recognize the loco id? Do you have other DCC locos on the track that have been reset? Is it a DCC READY or DCC fitted loco (easy mistake to make!) If it's a ready, there's no chip installed, just a blanking plate! It could be you have chosen a dirty bit of track, or the loco wheels need cleaning, before the Elite will recognize the on-board chip. They can be very fussy. If the loco will run in the default setting, let it circulate the track for a few minutes, to give all the pick-ups and wheels a polish, then try again. Link to comment Share on other sites More sharing options...
