Replacement metal wheel sets
HST Mainline
I have been replacing my older plastic and metal tyre versions as they deteriorate and I have often used the Hornby R8097 metal disc wheels. They are 12.6mm diameter and come in a pack of 12 axels. Other makes are available, of course.
Dapol, Hornby and Bachmann make replacement wheel / axle sets, all generally of the same general design - a centre-bushed (insulation) metal wheel pushed onto a metal axle.
They will have style and diameter options as well, so make sure you're not selecting a diameter too large for your wagons / bogies.
Axle lengths can vary, so be careful here.
Most will not have direct contact with the axles for power / conductivity if pickups were a consideration - but others are available.
Al.
