Flying Scotsman Coupling
Andy-374225
As 96RAF and Atom3624 have said, it looks as if a screw is not used at the loco end of the drawbar - in your image, light appears to be reflecting off the rounded end of a peg just behind the pony truck, and that peg simply fits in to the front hole in the drawbar.
Is the method of using the drawbar illustrated on the Operating and Maintenance Sheet that would have come with the set? (This is yet another example of a Service Sheet not having been issued for this locomotive.)
Running on her own ('light') or with a couple of coaches, that power supply will work OK.
If you start increasing the coaches - normal - power required will increase a little, and the supply will start cutting out.
Depending how much you want to invest, how far you want to go, it may be time to consider if you want to stay Analogue or go Digital (DCC).
Much better with very few locomotives than consider changing later on.
There's tons of information on YT.
Al.
