John-357061 Posted December 4, 2023 Share Posted December 4, 2023 I have setup ABC braking, works great when only the locomotive is drawing power. With the lighted coaches, the train slows down but does not always stop.looks like the issue is the coach is electrically connecting to the previous section of track. The obvious solution is to have the first coach only draw power from one side, not both. Suggestions for ways to try this out that would be reversible? Not cutting wires. Link to comment Share on other sites More sharing options...
Rallymatt Posted December 4, 2023 Share Posted December 4, 2023 Can you de-solder the pick ups onto the circuit board, I can’t remember how the Pullman lighting board looks. Link to comment Share on other sites More sharing options...
david_watts1 Posted December 4, 2023 Share Posted December 4, 2023 Without checking, could you remove one wheel set from each bogie and turn it around? Link to comment Share on other sites More sharing options...
John-357061 Posted December 4, 2023 Author Share Posted December 4, 2023 I need to try something like that. Thinking of putting the brake one first. Using the closed space for extra capacitors, if needed. I cannot see an easy way of doing this.The other thought I had is when the ABC stop section is occupied, connect the section before the stop section to the ABC section. The two combined would be longer than the trains I am planning on running. Need to figure out the best way to go. That will work with future purchases. Coaches of different lengths with lights. Link to comment Share on other sites More sharing options...
John-357061 Posted December 4, 2023 Author Share Posted December 4, 2023 Without checking, could you remove one wheel set from each bogie and turn it around?Would that not stop the lights from working?The more I think about it, switching the connection to the previous section, would give the most robust solution. Even with only one side connected, could stop over the join. Link to comment Share on other sites More sharing options...
96RAF Posted December 4, 2023 Share Posted December 4, 2023 The next decoder update will allow ‘trip’ sensitivity to be adjusted by way of CV128. Currently under test on a selected profile. Link to comment Share on other sites More sharing options...
ntpntpntp Posted December 4, 2023 Share Posted December 4, 2023 That's an interesting point about long trains with lighting pickups tending to bridge across into the ABC section. ABC's not something I've played with, and anyway I'm not a fan of lights in coaches, but I have seen similar issues with multiple units where the set is wired through. I have some Hobbytrain N gauge units which have switches factory-fitted to disable the pickups on the rear unit. Link to comment Share on other sites More sharing options...
John-357061 Posted December 5, 2023 Author Share Posted December 5, 2023 Thanks for your responses. Now I know how to slow down a locomotive. The ABC section or time on switch, is less than the fixed stopping distance / time.Did not realise the slowing down part could be interrupted. Link to comment Share on other sites More sharing options...
