Trevor-353714 Posted December 12, 2023 Share Posted December 12, 2023 I've had my TT layout for a good few months now, and had my Trigo running around. I haven't done anything in terms of track cleaning or maintenance on the loco. As quite a newbie, should I have been? If so, what? Do others ever do much? Link to comment Share on other sites More sharing options...
Fishmanoz Posted December 12, 2023 Share Posted December 12, 2023 Trevor, could you please use the 3 dots menu on the right of your post, select Edit, then amend your title to read “Routine Track and Loco Maintenance”. That way people will know what you want to find out about and are more likely to reply. And while you’ve only asked about the track, loco maintenance keeping wheels clean and pickups tensioned is part of it. Dirt will transfer from one to the other if not all clean. Link to comment Share on other sites More sharing options...
GMD Posted December 12, 2023 Share Posted December 12, 2023 TrevorLots of options and preferences when it comes to keeping track, wheels and pickups clean. Nothing especially distinctive as far as TT scale goes compared to 00.The most basic bit of kit is a track rubber, some like it, some don’t!Others prefer a specialist track cleaning solution, which you rub over the rail head to remove grime.Others opt for IPA and a rag.Then there are specially converted wagons that have devices to wipe the track as they go past when attached to a loco, though Hornby don’t have one of these in TT, not yet anyway. Overall, any method will suffice, but yes, after months of use, it is certainly time for a wee clean! Happy holidays! Link to comment Share on other sites More sharing options...
BritInVanCA Posted December 13, 2023 Share Posted December 13, 2023 I’ve had an A4 Falcon since about June. My track is on a baseboard that I keep clean. The other day I took a deep breath and removed the base keeper plate. I was amazed how much oil was in there which had caused quite the build up of debris. I cleaned it up and cleaned the pickups with a liquid cleaner. A good reminder of necessary maintenance. It certainly challenged my eyesight and dexterity Link to comment Share on other sites More sharing options...
Rallymatt Posted December 13, 2023 Share Posted December 13, 2023 On subject of maintenance, don’t forget your rolling stock wheels, unpowered wheels always pick up more dirt than ones with a current flowing through. It’s surprising just how much and build up casing the wheel ‘tyre’ to be uneven. For lubrication, use the right lubricant for the job, leave stuff like 3 in 1 for the lawnmower and never use WD 40 (it’s not a lubricant). Use a pin to pick up a tiny drop of oil and transfer it to the clean surface to be lubricated. Even the very narrow nozzles on some bottles will over supply. Take great care when cleaning the pick up wipers on wheels, they are delicate phosphor bronze and will damage easily. If you have removed wheels with contacts, a pair of cranked tweezers are useful to squeeze the contacts towards chassis while putting wheel sets back in, never force them. Link to comment Share on other sites More sharing options...
