Doncaster Enterprise 47522
MattR
Hello MattR
Rather than an opinion, I will use science. An image may be color sampled, and the color codes extracted. I prefer to work in RGB, but other codes are presented.
I sampled the photo in 4 places to determine the roof color. Note that some small variation is present, but I get an average RGB of 224, 215, 200. The location of each sample is shown, and the associated color codes.
I then pulled up your two colors and sampled them, as I could not immediately find the color code.
Railmatch silver grey is closest at RGB 206,208,195.
Railmatch diesel roof grey further away at RGB 169,168, 150
Be aware that colors presented on the web may not precisely match true colors.
Further, for a best match, we should sample the roof in many places and then take the color code to a store to dial in the color directly.
Bee
Hi Bee
thanks so much for your help with this - that’s really helpful and much appreciated.
Your analysis also confirms why I’m so often disappointed with the various renditions of BR blue - I’ve tried just about all the off the shelf one’s. But as many others on this forum and elsewhere have done many times, there’s no sign of these sorts of debates ending anytime soon with all the variables that you mention.
best, Matt
Another candidate, RailMatch 2303 BR Diesel Light Grey.
You can't reliably get a colour match from using a jpg picture alone, you will get a rough idea in this case a light grey. Image caption 'in unique LNER apple green postal livery' raises the question are all the colours LNER or just the apple green.
Simon's recommendation, color sampled. Closer yet!
Instead of color sampling swatches, Railmaster probably has a color code associated with these paints. May I strongly recommend you find that.
Secondly, if there are a few images of 47522, they should be sampled as well. The more we have, the better the result. Simon is correct, 1 image is subject to all kinds of subtle influences.
Interestingly, if I sample the roof near the top, instead of the previous locations, I get a near match for Simon's recommendation!
Bee
Hello Simon
The image you present has an RGB color code of 61, 73, 85. This is far, far away from the other photograph.
Matt's referenced photo is from 1987; yours from 1988, per the captions. The captions indicated wrecks, implying repaint.
I have no illusions about which color is correct or appropriate. This isn't the railway of my interest, nor of its details. I simply was trying to get MattR to see a way forward for his image and color choices. Professionals use color codes. Color codes can be extracted, albeit with some variation as it is sampled.
The best approach would be to get the color code from the records, as it was painted. Failing that, sample the locomotive directly, if is available in the livery of interest, noting that colors fade over time. Failing that, a color image will do. Etc.
Each, in turn, will provide less fidelity. But unless absolute precision is demanded (example, a new advertisement requiring the specific corporate shades) a photo will be fairly close enough.
Perfect? Probably not.
And I do not think you "failed". You added valuable input to getting us closer to Matt's image and color. Even another photograph, albeit probably a repaint. Thank you!
Bee
