William Whitelaw issue with Next18 HM7000
TaffsTT
Hi,
Purchased a TT120 A4 (William Whitelaw in a non HM7000 set).
Purchased a HM7000 Next18 chip, and fitted.
However, sound comes on but when it starts to go, it cuts out (like its a short or something as connection also gets lost to app).
Worked fine on dc before and when I restore loco back with a blanking chip.
Any ideas or issues encountered with this chip / loco combo please thst might help me?
Cheers
Nope - SD999 is the decoder factory default. You need SD038 for a TT A4.
Go to profiles and scroll along until you get to it then select your decoder ID from the drop down. Install as usual.
If you try to do it from loco settings >> select profile it may crash or hang or not. Either way whatever works for you.
@TaffTT - check to ensure you are fully seating the decoder in the socket (you should feel & hear a ‘click’ when correctly installed.)
If that is already the case, then your issue sounds remarkably similar to the following thread:
https://uk.hornby.com/community/forum/r1255m-and-8txs-bluetooth-disconnects-375842?ccm_paging_p=3#end-of-replies
(only difference is Next18 decoder rather than 8 pin.)
Seeking assistance from the developers by emailing: hm.customercare@hornby.com might therefore be advisable.
Tried that thanks - just in case but the same happens. The fault above is exactly the same issue!!
No assumptions regarding decoder waveforms or specific faults were intended in my post.
I was only suggesting that if the loco performs correctly, reliably and demonstrates faultless behaviour, when run on DC - then a socket/decoder issue appears more likely than a motor/chassis one.
However it is certainly not impossible for an intermittent motor/chassis fault to only appear under very specific conditions.
