Bugsy1957 Posted January 7 Share Posted January 7 Platform track geometry question: If I was to but Hornby straight platforms (E,g, R460) what would be the track spacing I would need to make these work without fouling the trains?I've attached the sort of thing I am think of. This is obviously not a full layout!Thanks Link to comment Share on other sites More sharing options...
96RAF Posted January 7 Share Posted January 7 That looks just right to me. Normal Hornby loop to loop geometry is 67mm centre to centre. https://support.hornby.com/hc/en-gb/article_attachments/10406061442332For exact track spacing Scarm has a measuring tool so you can go centre to centre or inner rails to inner rails, etc to compare with the platform width which should be on the product page, although the Scarm ones are accurate to planform. Link to comment Share on other sites More sharing options...
Bugsy1957 Posted January 7 Author Share Posted January 7 That looks just right to me. Normal Hornby loop to loop geometry is 67mm centre to centre. https://support.hornby.com/hc/en-gb/article_attachments/10406061442332For exact track spacing Scarm has a measuring tool so you can go centre to centre or inner rails to inner rails, etc to compare with the platform width which should be on the product page, although the Scarm ones are accurate to planform. SCARM shows about 132 mm between tracks where I have placed the platform which should be enough but is it too much? Ta Link to comment Share on other sites More sharing options...
Rallymatt Posted January 7 Share Posted January 7 As with all model railway stuff, there are compromises. The Hornby sectional track and platforms are designed to work together and take account of the overhang and corner cutting of the longest items they make, sometimes it can appear the platforms are too far back from the track but that’s the compromise. The alternative is to make your own platforms to accommodate the specific stock you run but it still might not be that different. Link to comment Share on other sites More sharing options...
96RAF Posted January 7 Share Posted January 7 Centre throw of long wheelbase stock will be your main problem entering the lay-by bit. Main line can be set realistically closer. You may have to lay it out on a board to check clearance then work that into your plan using flexi if necessary to join to the set-track curves spacing. Link to comment Share on other sites More sharing options...
Brew Man Posted January 7 Share Posted January 7 When it comes to platforms and quite a number of other buildings, I tend to go for Metcalfe kits. You can tailor them to suit your needs. Link to comment Share on other sites More sharing options...
M. Matthews Posted January 7 Share Posted January 7 Try it with R628 curves instead Link to comment Share on other sites More sharing options...
Bugsy1957 Posted January 7 Author Share Posted January 7 Thank you everyone for your tips - duly noted Link to comment Share on other sites More sharing options...
Simmo009 Posted January 7 Share Posted January 7 You have it completely correct in your diagram. The straight pieces match the track lengths, the R606 is the correct straightening piece to get back to parallel running, and the ramps follow the curves as you can see. Depending on your rolling stock, you may be able to get away with longer or wider, but you would need a kit or scratch build something. Link to comment Share on other sites More sharing options...
