ausrym Posted January 29 Share Posted January 29 Hi allI want to make up a small 2-coach branch line train. I want a brake 3rd corridor + a corridor composite.I'm thinking of R4685A (right hand) and R4687A (left hand) respectively? Do I need this combo so I can have the 3rd class all together and then the 1st closest to the loco?Or do I need 2 of the same 'handed' coaches? Link to comment Share on other sites More sharing options...
What About The Bee Posted January 29 Share Posted January 29 https://www.rmweb.co.uk/forums/topic/99359-left-hand-or-right-hand-coach-what-does-this-mean/As far as the location of first? The web is filled with this discussion. It comes down to a specific railway, at a specific station, at a particular time. The sense I got was: do what you think fits your specifics. Your mileage may vary, of course.Bee Link to comment Share on other sites More sharing options...
ausrym Posted January 30 Author Share Posted January 30 Thanks Bee, always a wealth of info from you. I want my consist to be Loco > (Coach 1: 1st compartments>3rd compartments) > (Coach 2: 3rd compartments >brake section).My take on that RMweb forum link is in order to make the above, I need it in this order: Loco > R4687A (LH) > R4685A (RH).Is that your reading Bee? If so I'll go buy them :D Link to comment Share on other sites More sharing options...
What About The Bee Posted January 30 Share Posted January 30 Hi AusrymMy reading suggests matching the handedness only applied to the GWR, and that the other railways were not like minded. The models you reference are BR, so I would suggest the GWR rules no longer were in play.Have fun!Bee Link to comment Share on other sites More sharing options...
Gordonvale Posted February 1 Share Posted February 1 The consideration is - passengers must be able to get on and off. Therefore depending on the positioning of platforms with regard to the rail:If platforms are always to the left, then both corridors cannot be to the right.If platforms are always to the right, then both corridors cannot be to the left.If platforms are both left and right, and there is a connection between coaches, one corridor must be on the left and the other on the right.If platforms are both left and right, and there is no connection between coaches, one corridor must be on the left and the other on the right, and passengers must be herded in to the coach set for their destination. Link to comment Share on other sites More sharing options...
81F Posted February 3 Share Posted February 3 Although the coaches are in BR livery, some GWR practices continued into nationalisation. My tip would be to try and find photographs of similar sized trains on BR(W) and see how the coaches are arranged.I appreciate that it might be difficult to find the exact type of coach but as the GWR built many different designs coaches over the years that were handed I don't think the design will matter that much. Link to comment Share on other sites More sharing options...
