Green Field Railway Posted November 12, 2012 Share Posted November 12, 2012 Hi am building my first DCC layout and I have problem with my points. I have a Hornby Accessory Decoder's wired up to PECO PL-11 Surface Mounted Point Motor's. Problem is that the points switch one way fine but when I switch them back they don't seem to have the power to turn the point back? I can hear the motor's make a short burst but they don't have the power to switch the point back??? This happens on all three Accessory Decoder's is this because Peco point motors use more power?? I have a Hornby Elite should is maybe try CV settings? Link to comment Share on other sites More sharing options...
Green Field Railway Posted November 12, 2012 Author Share Posted November 12, 2012 All the points are free moving :) Link to comment Share on other sites More sharing options...
Rog RJ Posted November 12, 2012 Share Posted November 12, 2012 You may have the wiring crossed. Peco use the green wire for the common connection and Hornby use the black wire as the common on point motors. Link to comment Share on other sites More sharing options...
Green Field Railway Posted November 12, 2012 Author Share Posted November 12, 2012 Rog (RJ) said: You may have the wiring crossed. Peco use the green wire for the common connection and Hornby use the black wire as the common on point motors. I will check that out :) Link to comment Share on other sites More sharing options...
