roryon Posted November 14, 2012 Share Posted November 14, 2012 Hi I just got a new Elite Controller but it only comes with 1 x wire for pluging the controller to the track. I want to set up a second track for programming, any advice on the wire/cable that should be used? Thanks Roryon Link to comment Share on other sites More sharing options...
Flashbang Posted November 14, 2012 Share Posted November 14, 2012 Hi The two wires to a programming track can be of any sized flexible wire - loudspeaker twin flex etc as there is very little current flow while programming. I would avoid solid conductor wires e.g. bell wire, as there is a risk of this fracturing internally. Link to comment Share on other sites More sharing options...
roryon Posted November 14, 2012 Author Share Posted November 14, 2012 Flashbang said: Hi The two wires to a programming track can be of any sized flexible wire - loudspeaker twin flex etc as there is very little current flow while programming. I would avoid solid conductor wires e.g. bell wire, as there is a risk of this fracturing internally. brilliant thanks Link to comment Share on other sites More sharing options...
Blackbird Posted November 16, 2012 Share Posted November 16, 2012 It is correct, progamming track wire can be minimal as is only conducting signal strength current. Hence 'bell wire' or phone wire sizes could be used. Flashbang is over stateing the risk of fracturing, how much movement is involved in a supply to a programming track? Link to comment Share on other sites More sharing options...
Flashbang Posted November 16, 2012 Share Posted November 16, 2012 Blackbird said: Flashbang is over stateing the risk of fracturing, how much movement is involved in a supply to a programming track? A good point Blackbird. But we don't know whether a layout is being moved regularly or even occasionally, whether the track is lifted and relaid often or the DCC console removed and replaced with each operating season? So to avoid any risk of a solid wire breaking, IMO it is best to always use a flexible wire. Keep thin solid conductors like Telephone and Bell wire to the phone and door bell circuits where the cable is held by clipped into its position and never moves. Use flexible wires where there is any possibility (a risk) of it being moved, flexed or caught accidentally. Flexible wire is little or no more expensive really anyway! :-) Link to comment Share on other sites More sharing options...
