Terry-381238 Posted May 8 Share Posted May 8 Anyone know the firmware version that could be in a 2019 model of a R8213 Select, seen in a local s/h toy shop Link to comment Share on other sites More sharing options...
96RAF Posted May 8 Share Posted May 8 34 minutes ago, Terry-381238 said: Anyone know the firmware version that could be in a 2019 model of a R8213 Select, seen in a local s/h toy shop Check the numbers on screen at power up. Link to comment Share on other sites More sharing options...
Terry-381238 Posted May 8 Author Share Posted May 8 Thanks, but cant do as toyshop owner is reluctant to power up as damage maybe caused in doing so Link to comment Share on other sites More sharing options...
Rog RJ Posted May 8 Share Posted May 8 8 minutes ago, Terry-381238 said: Thanks, but cant do as toyshop owner is reluctant to power up as damage maybe caused in doing so In that case, run away! Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 8 Share Posted May 8 I believe we can say with confidence it won’t be at v1.6 which is what you need to handle sound decoder functions these days. You will be up for the £15 return to Hornby upgrade for that. If you decide to buy an item where turning it on to see if it works seems to be at your risk? Link to comment Share on other sites More sharing options...
