Paul-RMD Posted May 30 Share Posted May 30 Good evening I have an issue with a TTS decoder, I’m using a select controller The loco has stopped working and when I try reallocating the decoder it only flashes 3 times and still doesn’t work. Is their anyway to reset the TTS decoder. I have tried with another DCC chip and alls fine so presume the TTS decoder has a fault. Many thanks Paul Link to comment Share on other sites More sharing options...
Fishmanoz Posted May 31 Share Posted May 31 What firmware version Select? If at least v1.6, write 8 to CV8 to reset the decoder. Link to comment Share on other sites More sharing options...
Paul-RMD Posted May 31 Author Share Posted May 31 34 minutes ago, Fishmanoz said: What firmware version Select? If at least v1.6, write 8 to CV8 to reset the decoder. I will give that a try. Thanks for your help Link to comment Share on other sites More sharing options...
96RAF Posted May 31 Share Posted May 31 Does the decoder respond to address 3 and/or is the address you have tried to allocate within the range 1-59. Link to comment Share on other sites More sharing options...
