Lamborghini Temerario (Huracan Replacement)
Lamborghini have finally revealed the much-anticipated successor to the Huracán, and it’s called the Temerario.
The iconic V10 that’s been in their cars since 2003 is out, and in its place is a new twin-turbo 4.0-liter V8, paired with three electric motors. It’s got a hot-vee layout, which means the turbos sit between the two cylinder banks.
One motor is located between the engine’s crankshaft and the gearbox, while the other two are mounted on the front axle, allowing for front-wheel-drive operation for short distances in near-silence.
The engine alone puts out 789bhp, between 9000rpm and 9750rpm, with a 10,000rpm redline. Add the electric motors, and total output jumps to 907bhp, giving it a 0-62mph time of 2.7 seconds and a top speed of 213mph.
The electric motors provide torque-filling at low revs to reduce turbo lag, powered by a small 3.8kWh battery, which can be charged at rates of up to 7kW via AC.
Thoughts on this as the Huracán’s replacement? Should it be made in 1:8 scale by Pocher?
lamborghini temerario
  • Like 1
  • 3 weeks later...
