minimissile2 Posted December 23, 2012 Share Posted December 23, 2012 Hi everyone, I recently began converting my layout to DCC one bit at a time, but my favourite set is my Golden Arrow including 3 pullman coaches with table lighting. But what i wanna know is, is it possible to convert the coaches to DCC so I can switch the lights on and off or is it just a safer bet to leave them as they are? and will the coaches work on a DCC layout without being DCC themselves? Link to comment Share on other sites More sharing options...
Graskie Posted December 23, 2012 Share Posted December 23, 2012 The answer to your last question is yes. No change except that the lights will be on all the time unless on, say, a siding isolated from the main layout which is, of course, live all the time. Link to comment Share on other sites More sharing options...
minimissile2 Posted December 24, 2012 Author Share Posted December 24, 2012 Thank You, I wasn't sure and I didn't want to test it in case something went wrong. But do you know if the coaches would work with a DCC conversion and does anyone have any idea how I could go about doing this? Link to comment Share on other sites More sharing options...
Rog RJ Posted December 24, 2012 Share Posted December 24, 2012 minimissile2 said: Thank You, I wasn't sure and I didn't want to test it in case something went wrong. But do you know if the coaches would work with a DCC conversion and does anyone have any idea how I could go about doing this? There are a few options available for DCC conversions. The first is to fit a decoder in each coach and give them all the same address to allow them all to be turned on and off together. Second option is to have a single decoder in one coach and run a pair of wires from this decoder to all the coaches, with a "loop" of wire between carriages for flexibility. It is also possible to fit electrically conductive couplers or miniature plugs and sockets between coaches which allows them to be disconnected if needed. Link to comment Share on other sites More sharing options...
