x_and Posted July 16, 2011 Share Posted July 16, 2011 Hi. Put hornby surface mounted point motor on the hornby point decoder, connected via track to the elite. The motor clicks properly outward but makes hardly any effort on inward movement. This is the same for 3 different point motors on decoder outputs 1 and 2. A peco motor operates fine in the same set up. The hornby point motors work fine on an analogue switiching system. Can anyone advise where I'm going wrong with this. Thanks. Link to comment Share on other sites More sharing options...
Rog RJ Posted July 17, 2011 Share Posted July 17, 2011 Make sure you have the wiring correct.Hornby point motors use black as the common wire. Peco use green as the common Link to comment Share on other sites More sharing options...
x_and Posted July 17, 2011 Author Share Posted July 17, 2011 spot on thanks rog Link to comment Share on other sites More sharing options...
