flying platty Posted February 5, 2013 Share Posted February 5, 2013 can anyone help with this, I thought I read somewhere that once you have created your plan in trackmaster you can upload to railmaster. is this correct as i cannot see a way to do this. Link to comment Share on other sites More sharing options...
LMSTim Posted February 5, 2013 Share Posted February 5, 2013 Because TrackMaster produces geometric drawings to scale and RailMaster uses MIMIC diagrams which are not to scale and which only use vertical, horizontal and 45 degree track elements it would be very difficult to translate a TrackMaster drawing into RailMaster. Having said that it is incredibly easy to draw a track plan in RailMaster precisely because you can only use vertical, horizontal and 45 degree pieces. You'll do it in a fraction of the time it took to create your TrackMaster drawing. Another thing to bear in mind is that if you started off by using one of the built in plans in TrackMaster then most of them have already been done in RailMaster so you can just amend those. Hope that helps. Link to comment Share on other sites More sharing options...
flying platty Posted February 5, 2013 Author Share Posted February 5, 2013 ok thanks for the info, you would have thought this could be acheived as both products are Hornby and should be compatible, Link to comment Share on other sites More sharing options...
HarryLondon Posted February 8, 2013 Share Posted February 8, 2013 I just got back into model railways and am an architect by profession. I designed a 2m x 1.5m layout using TrackMaster, which was straightforward. Knowing about engineering drawing I knew it would be a virtually impossible task to get my TrackMaster drawing imported into RailMaster. They are two different animals. TrackMaster is much more precise in producing absolute scale drawings, whereas RailMaster uses block diagrams like the London Underground, so everything is approximate. If it's any consolation, my TrackMaster drawing had 514 pieces of track on it and I entered the drawing into RailMaster from a standing start in 20 minutes. Not bad. Link to comment Share on other sites More sharing options...
