malang66 Posted March 6, 2013 Share Posted March 6, 2013 HI All... does anyone know if the B-------n 8pin harness would work with the hornby R8249 decoder chip or is there a harness out there that will work with them Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 6, 2013 Share Posted March 6, 2013 It will work. The pin configurations are defined in the NMRA specification for DCC so are universal. Link to comment Share on other sites More sharing options...
malang66 Posted March 6, 2013 Author Share Posted March 6, 2013 Fishmanoz said: It will work. The pin configurations are defined in the NMRA specification for DCC so are universal. cheers for that will get some next time i order chips may be better than cutting plug off as had problems at weekend as you may have read in not happy chappy so was looking for easyer way and the seems the way.. Link to comment Share on other sites More sharing options...
geochoice Posted March 6, 2013 Share Posted March 6, 2013 I learned that too. Can get quite a choice of harnesses with 8 pin socket, easier to beggar that and not the chip saves £'s too, plus of course easy to remove or swap chips. Link to comment Share on other sites More sharing options...
malang66 Posted March 7, 2013 Author Share Posted March 7, 2013 geochoice said: I learned that too. Can get quite a choice of harnesses with 8 pin socket, easier to beggar that and not the chip saves £'s too, plus of course easy to remove or swap chips. ive seen a lot of people complaining about quality of wirring on chips lately.. think there may be a bad batch out there.. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted March 11, 2013 Share Posted March 11, 2013 It'll be the weak soldering of the wires to the chip and not the wires themselves that are causing issues... lack of care during manufacture... Link to comment Share on other sites More sharing options...
Fishmanoz Posted March 11, 2013 Share Posted March 11, 2013 Agree, bad batch with dry joints where wires connect to PCB at least, in fact may possibly be across the whole chip, and have said so on at least 2 other threads where this has come up. Link to comment Share on other sites More sharing options...
Augustus Caesar Posted March 11, 2013 Share Posted March 11, 2013 Yep.. a common problem often commented upon. I have only had one decoder lose one of its wires (4 function) and I managed to resolderit straight away, making it far stronger. I'm generally very careful with fragile stuff anyway so handling these hasn't been much of a problem although the wiring is extremely suspect at times. Quite why a small harness can't be attached to secure the fragile wires is beyond me. Well, maybe not... it may cost a few pence to add one! Link to comment Share on other sites More sharing options...
