Bluehornby14 Posted July 20, 2011 Share Posted July 20, 2011 I am thinking of converting my hornby set from DC to DCC. Would i be able to use a C912 transformer(16v) plugged into the select controller. Link to comment Share on other sites More sharing options...
Brightstar Posted July 20, 2011 Share Posted July 20, 2011 You should consider purchasing the dedicated DCC transformer C7025 4Amp Digital. Tjhis will ensure that you have sufficient power available when you expand your layout and you need this if you upgrade to an Elite controller. You can then use the Select as a slave controller connected to the Elite. Link to comment Share on other sites More sharing options...
silverfox22 Posted July 20, 2011 Share Posted July 20, 2011 can any one help me when my train is moving round the track it slows done then it picks up what is the problem can you tell me please Link to comment Share on other sites More sharing options...
silverfox22 Posted July 20, 2011 Share Posted July 20, 2011 hi brightstar can you help i have d c c lay out but when my train runs round the track it slows down then it pick up speed can you tell me why Link to comment Share on other sites More sharing options...
Flashbang Posted July 21, 2011 Share Posted July 21, 2011 Hi1) Clean all rail tops - use a tack rubber or the rough side of a small piece of Hardboard (Masonite). I also use a lint free cloth with (IPA) Isopropanol Alcohol applied as a 'maintenance clean' every week or so. I also use a track rail cleaning truck which is filled with IPA and pushed around by a large loco.2) Ensure all metal rail joiners (fishplates) are tight onto each end of the rails they connect together, if you rely on this means of transferring power rail to rail. `if necessary use a pair of pliers to carefully 'crimp' the joiners bottom edge to the rails foot area. A DCC power Bus of two reasonably sized wires with smaller dropper wires to the rails above is far better for power/data transfer, especially if your layout is a permanently fixed down one.3) Clean the wheel treads of all wheels especially those that collect power. I use a fibre pencil for this, but you can use a powered PL40 wheel cleaning set.4) Ensure any wheel wiping contacts that rub on the rear inside of the wheels are actually touching the wheels inner face all the time, even when the wheel is moved across the loco. 5) Ensure the inner faces of the wheel wiping contacts and the inner faces of the wheels where the wipers touch are clean too. Again I find the fibre pencil is idea for this.Remember with DCC, cleanliness is next to perfect running. :-) Link to comment Share on other sites More sharing options...
silverfox22 Posted July 21, 2011 Share Posted July 21, 2011 Flashbang said:Hi1) Clean all rail tops - use a tack rubber or the rough side of a small piece of Hardboard (Masonite). I also use a lint free cloth with (IPA) Isopropanol Alcohol applied as a 'maintenance clean' every week or so. I also use a track rail cleaning truck which is filled with IPA and pushed around by a large loco.2) Ensure all metal rail joiners (fishplates) are tight onto each end of the rails they connect together, if you rely on this means of transferring power rail to rail. `if necessary use a pair of pliers to carefully 'crimp' the joiners bottom edge to the rails foot area. A DCC power Bus of two reasonably sized wires with smaller dropper wires to the rails above is far better for power/data transfer, especially if your layout is a permanently fixed down one.3) Clean the wheel treads of all wheels especially those that collect power. I use a fibre pencil for this, but you can use a powered PL40 wheel cleaning set.4) Ensure any wheel wiping contacts that rub on the rear inside of the wheels are actually touching the wheels inner face all the time, even when the wheel is moved across the loco. 5) Ensure the inner faces of the wheel wiping contacts and the inner faces of the wheels where the wipers touch are clean too. Again I find the fibre pencil is idea for this.Remember with DCC, cleanliness is next to perfect running. :-) Link to comment Share on other sites More sharing options...
silverfox22 Posted July 21, 2011 Share Posted July 21, 2011 thanks flashbang now can tell me if my analog trains cab be converted to d c c if so what decoder would i need Link to comment Share on other sites More sharing options...
silverfox22 Posted July 22, 2011 Share Posted July 22, 2011 silverfox22 said:thanks flashbang now can tell me if my analog trains cab be converted to d c c if so what decoder would i need Link to comment Share on other sites More sharing options...
silverfox22 Posted July 22, 2011 Share Posted July 22, 2011 any one tell me what is the best way to clean my track i have used a track rubber but not very good results Link to comment Share on other sites More sharing options...
Flashbang Posted July 22, 2011 Share Posted July 22, 2011 HiMost, if not all, dc locos can be converted to DCC.Some are just a matter of removing a 'dc operation blanking plug and then plugging in a decoder (DCC Ready loco), while others have to be 'Hard wired' by soldering the decoder wires to the motor connections and the wires from the wheel pickups. With this later style of loco you MUST always test the motor before attempting to connect and power up the loco on DCC. You need to ensure both of the motor connections are not in anyway in contact with the wheels or the locos metal chassis. Use a multimeter set on its OHMs range or a simple battery powered buzzer fitted with a pair of test leads. No reading or buzz should be observed. If there is a reading/buzz then the cause MUST BE ELIMINATED before proceeding. Failure to carry out this testing and remove any connection motor to wheels or chassis will normally result in total decoder failure! Normally noted by a puff of smoke seen rising from the decoder!!!As for rail cleaning, read my reply above - Paragraph 1.On modern Nickel Silver rail never use anything abrasive like sand / glass paper, emery cloth etc.Only on very old steel rail, which is rusted can a very fine grade of Emery cloth be used to remove any surface rusting.The determine if your rails are steel or nickel silver use a magnet. NS rail won't be attracted to the magnet where steel rail will. Link to comment Share on other sites More sharing options...
