PomDave Posted June 5, 2011 Share Posted June 5, 2011 Hi All, From browsing the web site I note that Hornby have 4 electric locootives with panographs but I annot find anything on the overhead cantenary systems for them, I have look elsewhere and the seems to be a total lack of anything on the markey axcept scratch-built. Can anyone direct me to the right area for such systems. Best Rgds Dave R. Link to comment Share on other sites More sharing options...
58001 Posted June 5, 2011 Share Posted June 5, 2011 Electrotren, Hornby's spanish division makes a reasonable overhead catenary system that won't hurt the wallet too much. Link to comment Share on other sites More sharing options...
VESPA Posted June 5, 2011 Share Posted June 5, 2011 Try Guagemaster Controls under 00 and search catenary........... I cannot link on here under Firefox browser as it seems to not work. You will see various styles. Dapol are also going to produce some or may have done !! Link to comment Share on other sites More sharing options...
bocaj Posted June 5, 2011 Share Posted June 5, 2011 I have heard d@pol do a good one but I'm not sure. Just to warn you if you are using DCC cantenary systems don't work too well on DCC, Hope this helps, JacobBechio has done it again for leeds, right into the top corner, Leeds have won the game Link to comment Share on other sites More sharing options...
mjohnson Posted June 5, 2011 Share Posted June 5, 2011 I'm not sure where you get the idea cantenary systems are bad for DCC. Sure, adding a DC power input (either + or -) to the cantenary would cause a problem, but shouldn't be an issue using AC (DCC). Link to comment Share on other sites More sharing options...
trainlover23 Posted June 5, 2011 Share Posted June 5, 2011 I would not be sure I have alos heard the same Link to comment Share on other sites More sharing options...
bocaj Posted June 5, 2011 Share Posted June 5, 2011 I asked about one on the forum before it closed and most people said that cantenary systems don't work well on DCCBechio has done it again for leeds, right into the top corner, Leeds have won the game Link to comment Share on other sites More sharing options...
poliss Posted June 6, 2011 Share Posted June 6, 2011 Problem with live catenary on DCC. You can't turn your locos around. Think about it.-----------------------------Get off the line Bobby. Link to comment Share on other sites More sharing options...
58001 Posted June 6, 2011 Share Posted June 6, 2011 The problem with DCC via an overhead line is one of poor electrical connection. Electrical pick-up via the rails can be done through all of the wheels providing between two and nine points of contact per rail. Using a pantograph you have only one point of contact. The slightest bit of dirt on the overhead line will interrupt the DCC signal and stop the train. Link to comment Share on other sites More sharing options...
poliss Posted June 6, 2011 Share Posted June 6, 2011 Someone has explained it better than I can on the World Railfans Forum. "DCC requires a circuit, as you would expect. On 2-rail, one rail is the supply and the other is the return. With Märklin, the catenary is the supply and both rails are the return. When you try to use DCC with catenary, the catenary is the supply, but you can't use both rails for the return, because diesels and steam locos will still need the conventional 2-rail wiring. That means you have to pick one rail or the other for the return from the catenary circuit, and thus the loco can only operate when it is oriented appropriately. When you run a loco around a reversing loop, the orientation is reversed, and the return side of the loco will be on the supply side of the rails; both the pans and wheels will be connected to the supply side, so there is no circuit and it will not run. " http://www.worldrailfans.info/forum/viewtopic.php?f=2&t=8518&start=20">http://www.worldrailfans.info/forum/viewtopic.php?f=2&t=8518&start=20-----------------------------Get off the line Bobby. Link to comment Share on other sites More sharing options...
Brightstar Posted June 7, 2011 Share Posted June 7, 2011 poliss said: Someone has explained it better than I can on the World Railfans Forum. "DCC requires a circuit, as you would expect. On 2-rail, one rail is the supply and the other is the return. With Märklin, the catenary is the supply and both rails are the return. When you try to use DCC with catenary, the catenary is the supply, but you can't use both rails for the return, because diesels and steam locos will still need the conventional 2-rail wiring. That means you have to pick one rail or the other for the return from the catenary circuit, and thus the loco can only operate when it is oriented appropriately. When you run a loco around a reversing loop, the orientation is reversed, and the return side of the loco will be on the supply side of the rails; both the pans and wheels will be connected to the supply side, so there is no circuit and it will not run. " <a href=">http://www.worldrailfans.info/forum/viewtopic.php?f=2&t=8518&start=20">http://www.worldrailfans.info/forum/viewtopic.php?f=2&t=8518&start=20 ----------------------------- Get off the line Bobby. Link to comment Share on other sites More sharing options...
Brightstar Posted June 7, 2011 Share Posted June 7, 2011 2-rail systems - dummy catenary system. I think you will find that in most 2-rail systems the cantenary pick-up are dummies and therefore the overhead catenary system is not powered. The locos get their power and return from the rails. This does not apply to the Maerklin 3-rail system as the centre rail/studs supplies the power feed and the 2 outer rails the power return. This system has a power feed available to the catenary system and locos with suitable live catenary pick-ups can use the catenary pick-up or the centre rail/studs to power the loco. The Electric locos have a switch on the loco to select the power source. I note the comment about not being able to turn the loco run on a catenary system, but this applies in real life, as trains are driven from either end, without having to move the motive unit. A bit like push/pull steam trains. Link to comment Share on other sites More sharing options...
LCDR Posted June 7, 2011 Share Posted June 7, 2011 58001 said: The problem with DCC via an overhead line is one of poor electrical connection. Electrical pick-up via the rails can be done through all of the wheels providing between two and nine points of contact per rail. Using a pantograph you have only one point of contact. The slightest bit of dirt on the overhead line will interrupt the DCC signal and stop the train. Link to comment Share on other sites More sharing options...
LCDR Posted June 7, 2011 Share Posted June 7, 2011 These confounded red buttons seem to have a mind of their own! What I tried to post is --- "Many exhibition layouts representing overhead electrification actually have dummy catenary, picking up power through the rails as usual. This would overcome the poor contact and allow DCC to be used normally." Link to comment Share on other sites More sharing options...
LCDR Posted June 7, 2011 Share Posted June 7, 2011 Why does this forum not print what I type!! Many exhibition layouts which feature overhead electrification are actually using dummy catenary, and pick current up conventionally through the rails. DCC would therefore work as normal. Link to comment Share on other sites More sharing options...
VESPA Posted June 8, 2011 Share Posted June 8, 2011 Why not just use the catenary just for show and pick up the power from the rails? Link to comment Share on other sites More sharing options...
Brightstar Posted June 14, 2011 Share Posted June 14, 2011 Hi Pomdave,I found this supplier for catenary systems for 2 rail model railways:http://www1.conrad-uk.com/scripts/wgate/zcop_uk/~flN0YXRlPTQwMjEyNjQ3NjI=?direkt_aufriss_area=SHOP_B2C_TAB_HOBBY&~template=PCAT_AREA_S_browse&p_page_to_display=&catalogs_sub_id=sub3&aktiv=3&navi=oben_1It is for HO scale systems but should look alright with the 00 scale. They have the items priced in £s. Link to comment Share on other sites More sharing options...
Brightstar Posted June 14, 2011 Share Posted June 14, 2011 Hi PomDave,I have found the following supplier of catenary systems for 2 rail model railways:http://www1.conrad-uk.com/scripts/wgate/zcop_uk/~flNlc3Npb249UDkwX0NPUF9VSzpDX0FHQVRFMDY6MDAwMC4wMTIwLjJjOTc0ZjcxJn5odHRwX2NvbnRlbnRfY2hhcnNldD1pc28tODg1OS0xJn5TdGF0ZT00MDIxMjY0NzYy====?direkt_aufriss_area=SHOP_B2C_TAB_HOBBY&~template=PCAT_AREA_S_browse&p_page_to_display=&catalogs_sub_id=sub3&aktiv=3&navi=oben_1They also have the following:http://www1.conrad-uk.com/scripts/wgate/zcop_uk/~flNlc3Npb249UDkwX0NPUF9VSzpDX0FHQVRFMDY6MDAwMC4wMTIwLjJjOTc0ZjcxJn5odHRwX2NvbnRlbnRfY2hhcnNldD1pc28tODg1OS0xJn5TdGF0ZT00MDIxMjY0NzYy====?direkt_aufriss_area=SHOP_B2C_TAB_HOBBY&~template=PCAT_AREA_S_browse&p_page_to_display=&catalogs_sub_id=sub3&aktiv=3&navi=oben_1.The prices seem reasonable and they are priced in £s.The scale is HO but should look alright on 00. Link to comment Share on other sites More sharing options...
Brightstar Posted June 14, 2011 Share Posted June 14, 2011 Hi PomDave,I have tried to post information about two different catenary system which might suit your requirement, but the system has sent the posting off for review and it is possible that they will not be posted.The website is http://www1.conrad-uk.com/You should look on this site for hobbies/model railway/gauge HO and look for HO Conact wires Som---- and HO Aerial wire Vie-------The prices seem reasonable and are priced in £s.The HO gauge items should not look out of place on a 00 scale railway Link to comment Share on other sites More sharing options...
Brightstar Posted June 14, 2011 Share Posted June 14, 2011 Hi PomDave,Try this site http://www1.conrad-uk.com/look for Model Railways/HO Scale and aerial wires and contact wires.I haver tried 3 other postings but they have been refered. Link to comment Share on other sites More sharing options...
trainlover23 Posted June 15, 2011 Share Posted June 15, 2011 If you can get to Germany Conrads items are much cheaper there. Link to comment Share on other sites More sharing options...
Brightstar Posted June 15, 2011 Share Posted June 15, 2011 By the time you have paid the credit/debit card surcharge the price differential is negligable.The link for Conrad Germany is http://www.conrad.de trainlover23 said:If you can get to Germany Conrads items are much cheaper there. Link to comment Share on other sites More sharing options...
Brightstar Posted June 19, 2011 Share Posted June 19, 2011 I have been looking at Hornby a Hornby Locomotive Operation and Maintenance Leaflet dated 1989. In the section General Information/Pantagraphs sub-sections: (d) If the layout is Zero 1 powered the current should be collected from the track rails only. In this case refer to the Locomotive Module fitting leaflet. The Pantagraph can be in the up position if desired.(b) If a layout has a non-operational catenary system run the model with the pantagraph up and slide switch move away frm pantagraph.Zero 1 was Hornby's first attempt at digital control of a layout. I think that this is good advice and applies equally to DCC powered layouts. Link to comment Share on other sites More sharing options...
AshAndPikachu Posted June 19, 2011 Share Posted June 19, 2011 I don't know if these are for display or can really be used but there are some on New Modellers Shop.co.uk under the Electrotren Tab. Link to comment Share on other sites More sharing options...
