81F Posted April 18, 2013 Share Posted April 18, 2013 I have a number of locos of the same basic type fitted with the same decoder so I would like to customise their CV settings after arriving at a set that seems to work on one of them. In order to save time could I place 5 on the same programming track and go through the process or do I have to do each individually. I appreciate that I will have to change the address afterwards. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 18, 2013 Share Posted April 18, 2013 Interesting idea and I don't know for sure. Five might be a stretch as the programming track output is low power so may not take the load, but at least you should be able to do more then one. Let us know the answer if you give it a try. Even if something weird happens you can read the decoder to find out what happened. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 18, 2013 Share Posted April 18, 2013 Or just write 8 to CV 8 and start again. Link to comment Share on other sites More sharing options...
2e0dtoeric Posted April 19, 2013 Share Posted April 19, 2013 They would all have the same I.D. number, though, unless you redid them all again after, individually, so would you really gain anything? Link to comment Share on other sites More sharing options...
Bulleidboy Posted April 19, 2013 Share Posted April 19, 2013 You beat me to it Eric, I was just thinking along the same lines. I ask this in ignorance, as I have never done it - if you change the loco I.D. does this cancel/change the CV's? Link to comment Share on other sites More sharing options...
2e0dtoeric Posted April 19, 2013 Share Posted April 19, 2013 No, that's a different programme routine. BUT, you have to enter the loco I.D. before you can change any other cv's, just like when you add a new pre-fitted loco, and change the address to suit your purpose (they can't all be 003!), but it doesn't alter any of the other settings. Link to comment Share on other sites More sharing options...
Bulleidboy Posted April 19, 2013 Share Posted April 19, 2013 2e0dtoeric said: No, that's a different programme routine. BUT, you have to enter the loco I.D. before you can change any other cv's, just like when you add a new pre-fitted loco, and change the address to suit your purpose (they can't all be 003!), but it doesn't alter any of the other settings. Thank you. Link to comment Share on other sites More sharing options...
81F Posted April 19, 2013 Author Share Posted April 19, 2013 Many thanks Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 19, 2013 Share Posted April 19, 2013 Sorry, some fuzzy thinking going on here. You don't first select loco address before programming other CVs. Address is just one menu item under Loco, Direct, others being Accel/Decel, V Start, CV Read, CV Write etc. So if you have already programmed your locos with different addresses, then put all on the programming track together and start writing other CV values, all should be programmed, except to the extent all the locos together overload the system and none get programmed. Link to comment Share on other sites More sharing options...
Fishmanoz Posted April 19, 2013 Share Posted April 19, 2013 And sorry, I have to admit to breaking all the rules to come up with that info - I read the manual! Link to comment Share on other sites More sharing options...
2e0dtoeric Posted April 20, 2013 Share Posted April 20, 2013 That's criminal, Fishy! (I must have blinked and missed that bit!) Link to comment Share on other sites More sharing options...
