Fishmanoz Posted July 29, 2013 Share Posted July 29, 2013 It has been reported that at least some of the above set have been supplied with the R8206 DC power track instead of the correct DCC power track. The set will not operate correctly with this track as it has a capacitor between the rails which degrades the DC signal. If you are having trouble changing the loco address, this maybe the problem. Turn your power track over to check if the part number moulded into it is R8206, the DC track, or the correct R8262. If wrong, it is easy to fix - just flip open the little black cover adjacent to the connectors and snip off the legs of the little capacitor you find inside then recluse the cover. Thanks to the thread at https://www.hornby.com/forums/hornby-forums/hornby-digital/5253/#post62803 for pointing out the problem. Link to comment Share on other sites More sharing options...
Fishmanoz Posted July 30, 2013 Author Share Posted July 30, 2013 Just opened RM to be told there is new News which advises of the problem above, suggests the same solution and gives pictures to show exactly how it is done. Link to comment Share on other sites More sharing options...
