Montywb Posted August 8, 2013 Share Posted August 8, 2013 1.08 is available for download. Link to comment Share on other sites More sharing options...
Fishmanoz Posted August 8, 2013 Share Posted August 8, 2013 Does it have libraries for non-Hornby track? Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted August 9, 2013 Share Posted August 9, 2013 TrackMaster is a simple model railway design system using only Hornby set track pieces. It is not intended to use third party products, therefore is not a generic layout designer. Updates are being made for the future to allow additional Hornby items to be incorporated however it is not designed to be a CAD system of any kind, just a simple to use design tool to try out ideas and create layouts based on the Hornby track system within a maximum area of 7.5m x 7.5m. Link to comment Share on other sites More sharing options...
timward55 Posted September 1, 2013 Share Posted September 1, 2013 HornbyRailMasterSupport said: TrackMaster is a simple model railway design system using only Hornby set track pieces. It is not intended to use third party products, therefore is not a generic layout designer. Updates are being made for the future to allow additional Hornby items to be incorporated however it is not designed to be a CAD system of any kind, just a simple to use design tool to try out ideas and create layouts based on the Hornby track system within a maximum area of 7.5m x 7.5m. Link to comment Share on other sites More sharing options...
timward55 Posted September 1, 2013 Share Posted September 1, 2013 Hi can you point me to the upgrade file? It is not in the support section. Thanks Tim Link to comment Share on other sites More sharing options...
HornbyRailMasterSupport Posted September 1, 2013 Share Posted September 1, 2013 Your TrackMaster should download and install the update automatically, however if your PC is not connected to the Internet or your antivirus and/or firewall software is blocking the download then you can download and install the update setup file manually from www.powerpos.com/track-master/tm_setup108.exe. You should add TrackMaster as an exception to your Internet security software so that future updates download and install when they become available. You should also right-click on the icon you use to run TrackMaster, select "Properties", click on the Compatibility tab and ensure the box "Run as administrator" is checked. You can do this before or after installing the update. Link to comment Share on other sites More sharing options...
